BenQ BL2420PT 24" 2560x1440 5ms DVI HDMI DisplayPort LED Monitor with Speakers
Quicklinx: BSXSWS00 Mfr#: 9H.LCWLA.TBE
Diagonal Size: 23.8in
Max Resolution: 2560 x 1440
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
£203.91 ex VAT
£244.69 inc VAT
The BL2420PT boasts a 23.8''W 2560x1440 quarter-high-definition (QHD) display built with BenQ's advanced IPS technology, providing professionals in CAD/CAM, animation, video editing and graphic arts ultra-precise color rendition and over 77% working space to enhance their work efficiency and productivity.
BenQ BL2420PT - BL Series - LED monitor - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class B
Energy Consumption per Year
50 kWh
Power Consumption (On mode)
34 W
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.205 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
14 ms (typical); 5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, DisplayPort, VGA
Speakers
Integrated
Display Position Adjustments
Pivot (rotation), swivel, tilt
7 kg
Display Type
Energy Class
Class B
50 kWh
34 W
Diagonal Size
23.8"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.205 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
HDCP, Senseye 3 Technology, 100% sRGB colour gamut, EyeCare Utility, Low Blue Light Mode, Flicker Free technology, CAD/CAM Mode, Desktop Partition, animation mode
7 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , DisplayPort , DVI , HDMI , Headphones (mini-jack) , Audio line-in , USB 2.0 upstream , 2 x USB 2.0 downstream
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
90
Height Adjustment
140 mm
VESA Mounting Interface
100 x 100 mm
Security Slot Type
Kensington security slot
28 Watt
Power Consumption Stand by
0.3 Watt
On / Off Switch
Included Software
Display Pilot
BenQ BL2420PT 24 Bundle deal on BenQ BL2420PT 24" 2560x1440 5ms DVI HDMI DisplayPort LED Monitor with Speakers
£303.08
BSXS C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BSXS C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.75
BSXS C2G 5m Select High Speed HDMI with Ethernet In Stock £22.51
BSXS C2G 10m Select High Speed HDMI with Ethernet In Stock £43.25
BSXS C2G 15m Select High Speed HDMI with Ethernet In Stock £58.57
BSXS C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
Response Time: 5ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: BenQ
Price Range Ex VAT: 150 - 300
