Featuring 16:10 widescreen aspect ratio, 100% sRGB, flicker-free technology, Senseye reading mode and eye protect sensor, the BL2411PT is tailor made is tailor made to meet the exceptional screen performance and superb user experience.
A win-win decision for mutual benefits
Designed for business environments, the BenQ BL2411PT of professional monitors is an essential part of your solutions to minimize total cost of ownership and maximize staff productivity - a win-win decision for the benefits of all. -
Visual performance
For viewing videos from HD camcorders or photos on digital cameras, the monitor reproduces 100% sRGB color to deliver authentic, natural visuals that match the color details of the original source perfectly. -
16:10 wide aspect ratio
16:10 widescreen aspect ratio offers 1920 x 1200 maximum resolution and the ease of viewing documents and working in multiple windows with minimized scrolling and toggling between applications. -
Ultra-flexible Height Adjustment System (HAS)
An extensive range of monitor adjustments - height, tilt, pivot, stroke and swivel - tailors to your unique build and viewing habits perfectly. -
Automatic eye-protect sensor
Ambient light levels are automatically detected to help adjust the monitor brightness throughout the day for optimized clarity and viewing comfort. -
Anti-glare display
A glare panel - whether it's caused by a direct or reflected light source - makes it a challenge for office workers to see clearly without straining their eyes. The BenQ BL2411PT monitors feature an anti-glare, matt-finish display to keep distracting reflections to a minimum, so office workers can work through their day-to-day tasks with well-improved efficiency - squint-free! -
Eco sensor
To help reduce energy waste and CO2 emissions, the eco sensor feature automatically switches the monitor to eco mode when you step away from your computer. This also helps lower your electricity costs effectively.
- BenQ BL2411PT - BL Series - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- Full HD 1920 x 1200
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 90 - 264 V
- Black
- 44.4 cm x 23.6 cm x 55.5 cm
- 6.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, EN 60950, TUV Ergo, ISO 9241-307
- 3-year warranty
- Display Type
- Diagonal Size
- 24"
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, H/V position, sharpness, colour balance, input select, colour temperature
- HDCP, Eco-Mode, anti-glare, Advanced Motion Accelerator (AMA) technology, Senseye 3 Technology
- Black
- 44.4 cm x 23.6 cm x 55.5 cm - with stand
- 6.7 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1 Watt
- VGA , DVI-D (HDCP) , DisplayPort , Headphones , Audio line-in
Mechanical
- Tilt Angle
- -5/+20
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x audio cable
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- AC 90 - 264 V
- Power Consumption (Typical)
- 23 Watt
- Power Consumption Stand by
- 0.3 Watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - on-site - response time: 3 days
- 5 °C
- 40 °C
- 20 - 90%
