BenQ BL2405PT 24" 1920x1080 5ms VGA HDMI DisplayPort LED Monitor
Quicklinx: D8J6WS00 Mfr#: BL2405PT
Stable feedback technology prevents the harmful effects of flickering that strain the eyes. Unique BenQ Low Blue Light Technology is designed to filter out harmful blue light, effectively diminishing eye fatigue and irritation.
  • Flicker-free
  • Low Blue Light
  • Height Adjustment Stand (HAS)
    The HAS allows you to find the best viewing angles for personal work or screen sharing with an extensive range of monitor adjustments.
BenQ BL2405PT - BL Series - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
22 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
2 ms (gray-to-gray), 5 ms (tr - tf)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Voltage
AC 120/230 V
57.9 cm x 6.3 cm x 35 cm
5.3 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class A
32 kWh
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
HDCP, Advanced Motion Accelerator (AMA) technology, Dynamic Power Saving (DPS), Low Blue Light Mode, Flicker Free technology, Colour Temperature Selection, 72% NTSC colour gamut
57.9 cm x 6.3 cm x 35 cm - without stand
5.3 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , HDMI , DisplayPort , Audio line-in/out , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Height Adjustment
110 mm
1 x DisplayPort cable - 1.5 m , 1 x VGA cable - 1.5 m
MTBF
60,000 hour(s)
Security Slot Type
Kensington security slot
Input Voltage
AC 120/230 V
22 W
Power Consumption (Typical)
33 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 57.9 cm - depth: 6.3 cm - height: 35 cm - weight: 5.3 kg , With stand - width: 57.9 cm - depth: 21.3 cm - height: 50.2 cm , With stand - width: 57.9 cm - depth: 21.3 cm - height: 39.2 cm
Sustainability Information
ENERGY STAR Certified
