BenQ 5J.JCK28.E01 Wireless Qcast Dongle Miracast
Quicklinx: BZZ7WS00 Mfr#: 5J.JCK28.E01
Wired / Wireless: Wireless
Protocol: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Compatibility: Android, Apple iOS, Mac, PC
Type: Network media streaming adapter
  • IEEE 802.11n
Hurry, only 1 left in stock!
£59.05 ex VAT
£70.86 inc VAT
Go from small screen to a big one for fun mobile entertainment sharing with loved ones using QCast! Thanks to the NFC wireless solution, you can enjoy the stunning tapNshow wireless experience, streaming 1080p multimedia contents from your smart device to BenQ projector with a simple tap.
BenQ Qcast - network media streaming adapter
External
3 cm x 8.4 cm x 1.4 cm
30 g
802.11b/g/n
LAN and Wireless Presentation
IEEE 802.11b/g/n wireless / Miracast
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, DLNA CERTIFIED
Android 4.0 or later, Microsoft Windows 2000/XP/Vista/7/8, Apple iOS 6.0 or later, Apple MacOS X 10.8 - 10.9
BenQ GP20, GP30, MW665, MW724, MW853UST+, MX600, MX602, MX723, MX852UST+, W1070+, W1080ST+, W1350
External
Wireless
Frequency Band
2.4 GHz
Firmware upgradable, USB powered, 2T2R MIMO technology, NFC support
1 x HDMI output - 19 pin HDMI Type A , 1 x USB 2.0 - 5 pin Micro-USB Type B (power only)
1 x USB power cable (external) , 1 x HDMI extension cable (external)
Encryption Algorithm
WPA, WPA2
3 cm
8.4 cm
1.4 cm
30 g
BZZ7 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BZZ7 C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.31
BZZ7 C2G 5m Select High Speed HDMI with Ethernet In Stock £21.05
BZZ7 C2G 10m Select High Speed HDMI with Ethernet In Stock £40.43
BZZ7 C2G 15m Select High Speed HDMI with Ethernet In Stock £54.75
BZZ7 C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: Apple iOS
Compatibility: Mac
Compatibility: PC
Brand: BenQ
Price Range Ex VAT: 50 - 100
