Your basket is empty
BenQ 3300 ANSI Lumens XGA DLP Chip Technology Ultra portable 1.9
Quicklinx: C6V1WS00 Mfr#: 9H.JFC77.13E
Offering lower TCO and optimized projection through dynamic power saving, uncompromised brightness, exquisite picture quality and optimized lamp life- SmartEcoTechnology has perfected what a DLP projector can do. With this innovation, schools and corporates are able to save up to 70% of lamp power consumption and lower maintenance costs through dynamic power saving features while bringing an ultra-vivid viewing experience into every presentation.
BenQ MX528 - DLP projector - portable - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Brightness
3300 ANSI lumens
Contrast Ratio
13000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
190 Watt
Bulb life cycle
Up to 4500 hour(s) / up to 6000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
270 Watt
28.3 cm x 22.2 cm x 9.5 cm
1.9 kg
DLP projector
3D Capable
Built-in Devices
Speaker
Projector
Brightness
3300 ANSI lumens
Contrast Ratio
13000:1
Image Size
152 cm - 762 cm
Throw Ratio
1.96 - 2.15:1
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 102 kHz
Bulb type
190 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Danish, Hindi, Hungarian, Czech, Croatian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Japanese, Korean
sRGB colour profile, ecoFACTS, SmartEco Technology, Dynamic Mode, SmartEco Mode, LampSave Mode
Lens
Lens Aperture
F/2.56-2.8
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x HDMI - 19 pin HDMI Type A , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type B , 1 x serial RS-232 - 9 pin D-Sub (DB-9)
Remote control
1 x VGA cable
Nominal Voltage
270 Watt
Power Consumption Stand by
0.5 Watt
28.3 cm
22.2 cm
9.5 cm
1.9 kg
C6V1 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.02
C6V1 C2G 5m USB 2.0 A/B Cable - Black In Stock £4.29
C6V1 C2G 2-Port USB 2.0 Manual Switch In Stock £16.36
C6V1 C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £11.41
C6V1 C2G 4-Port USB 2.0 Aluminum Hub In Stock £25.45
C6V1 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £14.97
C6V1 C2G USB 2.0 To Fast Ethernet Adapter In Stock £19.05
