Your basket is empty
BenQ 3200 Lumens XGA Resolution DLP Technology Meeting Room Proj
Quicklinx: BYL6WS00 Mfr#: 9H.JE177.13E
Portability: Portable
£450.62 ex VAT
£540.74 inc VAT
Designed to deliver crisp, bright, larger-than-life images from a short projection distance, the BenQ MX631ST is ideal for use in places where space is at a premium such as small conference rooms, training rooms and classrooms. With a powerful 3200 ANSI lumens bright image and an impressive 13000:1 contrast ratio, razor sharp image and rich, accurate colors, the MX631ST will help you present your best.
BenQ MX631ST - DLP projector - portable - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Brightness
3200 ANSI lumens
Contrast Ratio
13000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
196 Watt
Bulb life cycle
Up to 4500 hour(s) / up to 6500 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
305 Watt
28.73 cm x 23.26 cm x 11.44 cm
2.6 kg
DLP projector
3D Capable
Built-in Devices
Speaker
Projector
Brightness
3200 ANSI lumens
Contrast Ratio
13000:1
Image Size
152 cm - 762 cm
Throw Ratio
0.9 - 1.08:1
Resolution
XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 102 kHz
Bulb type
196 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Danish, Hindi, Hungarian, Czech, Croatian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Japanese, Korean
sRGB colour profile, USB host function, AudioPass, ecoFACTS, SmartEco Technology, ImageCare Technology, Eco Blank
Lens
Lens Aperture
F/2.6 - 2.78
Zoom Factor
1.2x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x USB - mini-USB Type B , 1 x USB - 4 pin USB Type A , 1 x audio line-in - RCA x 2 , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A
Wireless remote control
1 x VGA cable
Power Source
AC
Nominal Voltage
305 Watt
Power Consumption Stand by
0.5 Watt
28.73 cm
23.26 cm
11.44 cm
2.6 kg
Sound Emission
33 dBA
28 dBA
BYL6 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.02
BYL6 C2G 5m USB 2.0 A/B Cable - Black In Stock £4.42
BYL6 C2G 2-Port USB 2.0 Manual Switch In Stock £16.36
BYL6 C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £11.41
BYL6 C2G 4-Port USB 2.0 Aluminum Hub In Stock £25.45
BYL6 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £14.97
BYL6 C2G USB 2.0 To Fast Ethernet Adapter In Stock £19.05
Brand: BenQ
Price Range Ex VAT: 300 - 500
