Designed to deliver crisp, bright, larger-than-life images from a short projection distance, the BenQ MX631ST is ideal for use in places where space is at a premium such as small conference rooms, training rooms and classrooms. With a powerful 3200 ANSI lumens bright image and an impressive 13000:1 contrast ratio, razor sharp image and rich, accurate colors, the MX631ST will help you present your best.
Minimum space constraints
Imagine the freedom of having the same large size image from just half the traditionally required throw distance! Having increased placement flexibility and more efficient use of available space. That's the magic of short-throw! -
Zero eye-blinding lights
The short-throw projection distance keeps the projector light from shinning directly into your eyes, allowing you to keep your focus on your audience. -
Zero disruptions
With a projection distance this close, you will be able to move freely, without casting distracting shadows on the screen! -
High contrast
High contrast ratio adds depth to an image and is essential to provide crisp image detail. The high contrast ratio in the MX631ST helps produce images with stunning clarity and fine detail for sharper, easier to read text, graphics and video for more memorable presentations. -
High brightness
The high brightness of the BenQ MX631ST helps overcome most ambient light conditions to ensure your message will be seen clearly, even with the lights on. -
2 HDMI ports
Compatible with today's digital sources, the MX631ST provides Dual HDMI ports to satisfy your digital connectivity needs as well as dual VGA ports for traditional analog sources. -
Enjoy big screen fun from your Android devices with Plug 'N Play
You can now share content from your favorite MHL enabled devices on the big screen. The MHL functionality in the MX631ST allows you to display pictures, movies and games from MHL enabled Android devices to the big screen. -
Ease of use
When the projector is placed off center, the automatic keystone correction feature gives you wider projector installation flexibility by correcting the trapezoid effect using vertical adjustment automatically. -
Built-in speakers
Powerful built-in 10W speaker provides ample amplification to ensure your message is clearly heard. -
SmartEco lamp saving technology
Incorporating BenQ's renowned SmartEco lamp saving Technology, the MX631ST not only offers greater energy savings, but continues to deliver amazing picture quality through this innovative technology. SmartEco mode is designed to use only the exact amount of lamp power a projector needs to deliver the best contrast and brightness performance. This feature enables the MX631ST to deliver uncompromised projection quality with the added benefit of reduced the total cost of ownership by extending the lamp life and lowering power consumption. -
Blu-ray Full HD 3D supported
BenQ MX631ST is built with latest DLPR technology to support Full 3D functionality, allowing users to create immersive viewing experiences. Setup is easy. All that is required are 3D glasses and 3D content from your 3D Blu-ray player. -
Audio pass through
With the built-in speaker, the MX631ST can be used as an audio system when it's on the standby mode. This saves you the trouble as well as the extra budget for getting a separate audio system. -
Timeless image quality
BenQ uses Colorific technology to optimize images for specific color balance effects for diverse applications such as presentations, movies and spreadsheets and photographs. Every BenQ Colorific projector generates more than one billion colors by combining up to seven different colors to create vibrant, true-to-life images. You will also experience dramatic contrasts for remarkable image clarity, higher visual impact and greater legibility. You can rely on the colors to remain the same from day one to a decade later - without the risk of fading, ghosted images, or yellowing.
- BenQ MX631ST - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Brightness
- 3200 ANSI lumens
- Contrast Ratio
- 13000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- 196 Watt
- Bulb life cycle
- Up to 4500 hour(s) - normal mode , Up to 6500 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 305 Watt
- 28.73 cm x 23.26 cm x 11.44 cm
- 2.6 kg
- DLP projector
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Brightness
- 3200 ANSI lumens
- Contrast Ratio
- 13000:1
- Image Size
- 152 cm - 762 cm
- Throw Ratio
- 0.9 - 1.08:1
- Resolution
- XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 102 kHz
- Bulb type
- 196 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Danish, Hindi, Hungarian, Czech, Croatian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Japanese, Korean
- sRGB colour profile, USB host function, AudioPass, ecoFACTS, SmartEco Technology, ImageCare Technology, Eco Blank
Lens
- Lens Aperture
- F/2.6 - 2.78
- Zoom Factor
- 1.2x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -30 / +30
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
- 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x USB - mini-USB Type B , 1 x USB - 4 pin USB Type A , 1 x audio line-in - RCA x 2 , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Power Source
- AC
- Voltage Required
- 305 Watt
- Power Consumption Stand by
- 0.5 Watt
- 28.73 cm
- 23.26 cm
- 11.44 cm
- 2.6 kg
- Sound Emission
- 33 dBA
- Sound Emission (Economic Mode)
- 28 dBA
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.20 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.06 |
