BenQ 3200 Lumens WXGA Resolution DLP Projector
Quicklinx: B3L1WS00 Mfr#: 9H.JCH77.13E
Featuring a brightness of 3200 ANSI lumens and a high contrast ratio of 13000:1, the cost-effective and eco-friendly MW526 offers a stunning full-screen presentation with the finest details regardless of the ambient light level.
  • SmartEco mode
    The SmartEco Mode, which cleverly adjusts the lamp power to maximize power saving by delivering the best contrast and brightness performance using only as much light as needed.
  • LampSave mode
    Projector lamp replacement costs make up the biggest part of the total cost of projector ownership. The LampSave Mode is designed to adjust the lamp power dynamically by content brightness level to extend projector lamp life significantly by 50%! The lamp replacement frequency is also reduced by up to 50% to lower the replacement costs.
  • No source detected mode
    The automatic switch to Eco Blank Mode after the projector is turned on for over three minutes without a display source, eliminating unnecessary energy waste and prolonging the life of the projector lamp.
  • Blu-ray Full HD 3D supported
    BenQ MW526 is built with latest DLP technology to support 3D functionality, allowing schools to bring an immersive learning experience to their students with a simple preparation of 3D glasses and 3D content from your blu-ray player.
  • Long-lasting image perfection with DLP technology
    BenQ DLP Projectors are built with enduring enjoyment in mind, ensuring razor-sharp clarity, ultra-readability and true-to-life color for years to come. Benq use leading-edge DLP Technology to reflect pure light from millions of micro mirrors on a DMD chip through the advanced color wheels. Since the mirrors are colorless and protected within a nearly-sealed engine, BenQ DLP Projectors have no aging problems and are virtually immune to image decay, consistently delivering picture excellence time and time again. In fact, after 2,000 hours of intense usage, inserting a new bulb produces image quality comparable to a brand-new projector.
  • Razor-sharp clarity with ultra-readability
    Enabling a 96% fill factor, DLP technology supplies pixel circuitry behind the pixel, thereby eliminating the thick dark bezels around individual pixels, which diminish color and detail. A higher fill factor and less black border translate to noticeably purer, more intense color and smoother image quality.
  • Vibrant, true-to-life colors
    Even in lit venues, BenQ DLP Projectors achieve the optimal balance of brightness and color accuracy, with BrilliantColor Technology additionally boosting true-to-life colors that captivate. BrilliantColor enables up to six-color processing by incorporating the secondary colors Yellow, Cyan, and Magenta along with primary Red, Blue, and Green. From intense hues to elusive mid-tones like aqua blues and light yellows, your every presentation is rendered in pure, living splendor.
BenQ MW526 - DLP projector - portable - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Brightness
3200 ANSI lumens
Contrast Ratio
13000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
190 Watt
Bulb life cycle
Up to 4500 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
270 Watt
28.3 cm x 22.2 cm x 9.5 cm
1.9 kg
DLP projector
3D Capable
Built-in Devices
Speaker
Projector
Brightness
3200 ANSI lumens
Contrast Ratio
13000:1
Image Size
135 cm - 762 cm
Throw Ratio
1.5 - 1.65:1
Resolution
WXGA - WXGA (1280 x 800) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 102 kHz
Bulb type
190 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Danish, Hindi, Hungarian, Czech, Croatian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Japanese, Korean
sRGB colour profile, ecoFACTS, SmartEco Technology, Dynamic Mode, SmartEco Mode, LampSave Mode
Lens
Lens Aperture
F/2.56-2.8
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x HDMI - 19 pin HDMI Type A , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type B , 1 x serial RS-232 - 9 pin D-Sub (DB-9)
Lens cover, remote control
1 x VGA cable
270 Watt
Power Consumption Stand by
0.5 Watt
28.3 cm
22.2 cm
9.5 cm
1.9 kg
Sound Emission
33 dBA
28 dBA
