Product
BenQ 3000 Lumens XGA Resolution DLP Technology Install Projector
Quicklinx: CMRSWS00 Mfr#: 9H.JCA77.13E
Portability: Non-portable
15 in stock
£632.22 ex VAT
£758.66 inc VAT
Designed for disruption-free learning in small-sized classrooms, the MX842UST offers a big screen in short distance with a 0.47 ultra short-throw ratio. Together with 13000:1 ultra-sharp contrast ratio and 3000 ANSI lumen brightness, this projector has the most dynamic image quality to offer!
  • Efficiency installation with BenQ wall mount alignment system
    Designed to help ensure a fail-proof projector installation, BenQ has implemented extra help into its wall mount design. This installer-friendly ultra short-throw projector wall mount features an installation chart and a measuring ruler to help you find the most suitable projector-screen alignment and image position for your classroom.
  • Saving more on power consumption with BenQ's SmartEco technology
    Offering lower TCO and optimized projection through dynamic power saving, uncompromised brightness, exquisite picture quality and optimized lamp life - SmartEco technology has perfected what a DLP projector can do. Schools and corporate are able to save up to 70% of lamp power consumption and lower maintenance costs through dynamic power saving features while bringing an ultra-vivid viewing experience into every presentation.
  • SmartEco mode: power smarter
    By detecting the input content to determine the amount of brightness required for optimum color and contrast performance, the SmartEco mode is able to reduce lamp power while delivering the finest image quality. No compromise!
  • Eco blank mode
    The eco blank mode, which lowers power consumption up to 70%, can be used to blank the projection screen when the projector is not in use, in turn eliminating distractions in class and redirecting students' focuses back on the teacher.
  • No source detected mode
    The no source detected mode, which can be set to enter the eco blank mode after three minutes of inactivity or to the auto power off mode after no display source has been detected for over 30 minutes, can keep the projector from running with full lighting power.
  • Zero space constraints
    You don't need a big room or a lot of free ceiling space to create a big picture when you've got an ultra short-throw projector! Teachers can think outside the box to turn every corner into the perfect place for educational use.
  • Zero shadow disruptions
    An ultra short-throw projector can be placed close to the screen in front of the class and well out of students' way, greatly decreasing the occurrences of shadow disruptions. Teachers can enjoy teaching without worrying about the class being interrupted.
  • Zero eye-blinding lights
    An ultra short-throw projector keeps the projector light from shining directly into everyone's eyes. The intensity of the projector beam may be potentially harmful. So it's for the best to keep it out of the way.
  • Blu-ray Full HD 3D supported
    BenQ MX842UST is built with DLP technology to support 3D functionality, allowing schools to bring an immersive learning experience to their students with a simple preparation of 3D glasses and 3D content.
  • Projector management through LAN control
    LAN control is designed to help IT managers perform day-to-day projector maintenance and repair tasks efficiently and effectively - offering them full access and control over every projector directly from their workstations. The MX842UST offers seamless support for the Crestron LAN control system.
BenQ MX842UST - DLP projector - ultra short-throw - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Stereo speakers
Brightness
3000 ANSI lumens
Contrast Ratio
13000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Lens
Ultra short-throw lens
Bulb type
240 Watt
Bulb life cycle
Up to 3500 hour(s) - normal mode , Up to 7000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
330 Watt
33.9 cm x 32.28 cm x 23.69 cm
5.4 kg
DLP projector
3D Capable
Built-in Devices
Stereo speakers
Projector
Brightness
3000 ANSI lumens
Contrast Ratio
13000:1
Image Size
152.4 cm - 762 cm
Throw Ratio
0.47:1
Resolution
XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 102 kHz
Bulb type
240 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Danish, Hindi, Hungarian, Czech, Croatian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Japanese, Korean
BrilliantColor, ecoFACTS, SmartEco Technology, Auto Power Off, Eco Blank, On-Screen Help Display
Lens
Lens Aperture
F/2.53
Zoom Factor
1.5x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-15 / +15
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
10 Watt
Speakers
2 x right / left channel
1 x HDMI - 19 pin HDMI Type A , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x USB - 4 pin mini-USB Type B (management) , 2 x audio line-in - mini-phone 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x network - RJ-45 (management) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 2 x VGA / component video input - 15 pin HD D-Sub (HD-15)
Wall mounting kit, wireless remote control
1 x VGA cable
Nominal Voltage
330 Watt
33.9 cm
32.28 cm
23.69 cm
5.4 kg
Sound Emission
36 dBA
30 dBA
Brand: BenQ
Price Range Ex VAT: 500 - 750
