BenQ 2500 Lumens 1080p Resolution DLP Technology Projector
Quicklinx: BY50WS00 Mfr#: 9H.JD377.27E
Home entertainment is only a push of a button away! The W1350 living room projector is packed with BenQ's new-generation wireless projection capabilities and side projection feature to give you 100" of 1080p uncompressed Full HD fun wherever and however you like - no complex installations, tangled wires or remodeling costs. Plus, it's as simple to use as any home appliance!
  • New-generation wireless Full HD Kit
    The W1350 frees you from wiring troubles, placement hassles, as well as extra remodeling costs with BenQ's new-generation Wireless Full HD Kit. Available as an optional accessory, this powerful kit enables the W1350 to stream uncompressed, stunning 1080p Full HD content wirelessly - and with 3D support. So you can kick back, relax and enjoy your favorite movies and games!
  • Absolute convenience
    Only a few steps are required to set up the kit once and for all to give you plug-and-play convenience like no other. Once everything is connected correctly, the transmitter and the receiver will automatically pair up with the W1350 the first time you power them on - and turn on to re-connect with the projector every time after. To save you from all the cable trouble, the customized receiver box can be easily mounted to the right side of the W1350 and electronically charged by the projector instead of taking up another power socket. It just doesn't get easier than this.
  • Unparalleled transmission technology
    The W1350 comes with a wireless coverage of up to 30 meters (100 feet) in distance at line of sight and four built-in antennas to ensure the best streaming quality through cabinet doors and from one room to the next. The home projector also delivers a latency-free performance ideal for playing fast-action and motion-sensing games. Time to get ready for high quality audiovisual enjoyment and the smoothest gaming experience in the living room or in the privacy of your bedroom.
  • 10W immersive sound performance
    The built-in 10W resonant chamber speaker is expertly tuned to enhance the W1350's audio playback quality with deeper base tones - offering you a truly immersive audio performance that's free of stereo speaker wiring troubles. What's more, there are four preset sound modes and one equalizer setting available for you to match to the music of your choice for the most optimal audio enjoyment.
  • Side projection with horizontal keystone correction
    The horizontal, or side-to-side, keystone correction feature comes in handy when you have a hard time clearing up your living room table or finding an ideal placement for the W1350. By enabling you to correct the trapezoid effect, which occurs when a projector is placed off center, this feature offers you the flexibility you need to turn unused corners or space, such as the side table, into the perfect place for the W1350.
  • Flexible zoom & lens shift for extra installation freedom
    Say goodbye to changing your home décor to accommodate your projector or stacking books under it to fix the projection position again! The W1350 is built to free up your living space with a 1.5x flexible zoom that supports remodeling-free projector installation with an impressive range of projection distances. With the hardware Lens Shift feature, this home projector can correct the position of the projected image by shifting it vertically by 120% to 148% - without sacrificing the image quality! So you can avoid projecting onto existing furniture like TV shelves.
  • Spectacular Full HD 1080p picture performance
    The W1350 spoils your eyes with true-to-life image quality brought to you by BenQ's 1080p Full HD optimized optical system, which is made up of a projection lens that is comprised with only glass-made lens elements. So you can enjoy your favorite high-definition multimedia content with the best clarity and sharpness - from Blu-ray DVDs to video games and HD broadcasting.
  • 6X-speed RGBRGB color wheel
    A six-segment color wheel (RGBRGB) with six times the speed is adapted to produce incredibly realistic color depth and range - with BrilliantColor Technology further boosting every color to achieve a truly captivating, lifelike color performance. So you can enjoy the show in pure, living splendor.
  • Independent 3D color control for 6 primary colors
    For 100% uncompromised color customization, this color management tool allows you to fine-tune the gain, saturation and hue of six primary colors (R/G/B/C/M/Y) individually.
  • All-glass, low-dispersion coated lens
    Featuring BenQ's very own Full HD-optimized optical system, the W1350 ensures the best color performance, clarity and sharpness in every Full HD image. With all twelve of its projection lenses made of all glass material, the projector outperforms others with greater light penetration, preserving the truest image details for the most optimal viewing quality. What's more, a special low dispersion coating technology is applied to the lenses to minimize chromatic aberration or color fringes, a visual catastrophe manifested by unmatched sharpness and color saturation. As a result, the fullest and most vivid colors are delivered with superior sharpness to please your eyes.
  • 3D cinematic experience in the comfort of your home
    The W1350 supports multiple forms of 3D with amazing 1080p Full HD quality, including HDMI 1.4a 3D, Blu-ray, 3D broadcasting, video games and NVIDIA 3DTV PC connectivity - crosstalk free. So you can maximize your 3D enjoyment with ease.
  • Highly responsive for gaming in the fast lane
    With a high response time and low latency rate, the W1350 makes an ideal video gaming mate for you and your loved ones. An ultra-smooth projection means you get an uninterrupted, immersive fast-motion gaming experience when you're racing through the lanes with your PS4 or having a swing at the boxing match with your X-Box Kinect.
  • SmartEco mode
    The SmartEco Mode, which cleverly adjusts the lamp power to maximize power saving by delivering the best contrast and brightness performance using only as much light as needed.
  • No source detected mode
    The automatic switch to Eco Blank Mode after the projector is turned on for over three minutes without a display source, eliminating unnecessary energy waste and prolonging the life of the projector lamp.
  • Timeless image quality
    BenQ DLP Projectors are built with enduring enjoyment in mind, ensuring razor-sharp clarity, ultra-readability and true-to-life color for years to come. BenQ use leading-edge DLP Technology to reflect pure light from millions of micro mirrors on a DMD chip through our advanced color wheels. Since the mirrors are colorless and protected within a nearly-sealed engine, BenQ DLP Projectors have no aging problems and are virtually immune to image decay, consistently delivering picture excellence time and time again. In fact, after 2,000 hours of intense usage, inserting a new bulb produces image quality comparable to a brand-new projector.
BenQ W1350 - DLP projector - 3D
DLP projector - 1080p
3D Capable
Yes (3D glasses included)
Built-in Devices
Speaker
Microdisplay
DarkChip 3
Brightness
2500 ANSI lumens
Contrast Ratio
10000:1
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Lens Shift Direction
Vertical
Bulb type
260 Watt
Bulb life cycle
Up to 2000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
Video Input
RGB, composite video, component video (NTSC, SECAM, PAL)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
330 Watt
33 cm x 24.7 cm x 11.95 cm
3.68 kg
3D Capable
Built-in Devices
Speaker
Projector
Microdisplay
DarkChip 3
Brightness
2500 ANSI lumens
Contrast Ratio
10000:1
Image Size
66 cm - 826 cm
Throw Ratio
1.39 - 2.09:1
Resolution
Full HD - Full HD (1920 x 1080) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
120 Hz x 102 kHz
Bulb type
260 Watt
Bulb life cycle
OSD Languages
Danish, Hindi, Hungarian, Czech, Croatian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Japanese, Korean
DarkChip3 single-chip DLP technology, ISFccc, ecoFACTS, SmartEco Technology, Eco Blank, MHL compliance, NVIDIA 3DTV Play ready
Lens
Lens Aperture
F/2.42-2.97
Zoom Factor
1.5x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Vertical
Vertical Lens Shift
120% / 148%
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x component video input - RCA x 3 , 1 x composite video input - RCA , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone 3.5 mm , 1 x USB - mini-USB Type B , 1 x USB - 4 pin USB Type A
Lens cover, wireless remote control
Power Source
AC
330 Watt
Power Consumption Stand by
0.5 Watt
33 cm
24.7 cm
11.95 cm
3.68 kg
Sound Emission
34 dBA
32 dBA
BY50 C2G 5m USB 2.0 A/B Cable - Black In Stock £5.09
