Enjoy 1080p Full-HD image projection up to 200" in the comfort of your living room with the W1070 Home Entertainment Projector. You'll be captivated by brilliant image performance featuring a 10,000:1 contrast ratio and a 2000 lumen brightness. Built-in speakers and easy set-up seal the deal on this user-friendly experience.
Full HD 1080p
Showcase Full-HD content in sharp, 1080p definition and enjoy Blu-ray, video games and HD broadcasting in beautiful, high-contrast quality without downscaling or compression. -
ISF Certification
The W1070 is ISF Certified for customization to any room, offering calibration for optimized color performance in both Day and Night modes that can adapt to any room's layout, size and ambient light levels. -
3D
The W1070 supports multiple forms of 3D - including HDMI, Blu-Ray, 3D broadcasting, video games and NVIDIA 3DTV PC connectivity - in 1080p Full-HD for maximum enjoyment. You'll appreciate uninterrupted viewing with no crosstalk thanks to DLP technology and new glasses designed for comfort and peak image quality. -
Built-in speakers
Built-in speakers are Plug-and-Play ready, only the power cord and video source connection are needed to prepare the viewing experience. -
Rich connectivity
Play from many devices with HDMI x 2 and multiple connectivity options. -
World-Leading SmartEco technology, green up your living room
Offering Lower maintenance cost and Optimized Projection Through Dynamic Power Saving Uncompromised brightness, exquisite picture quality and optimized lamp life - BenQ's SmartEco technology has perfected what a DLP projector can do in home entertainment projector. With this special innovation, you are able to save up to 70% of lamp power consumption and lower maintenance costs through dynamic power saving features while bringing an ultra-vivid picture quality in every living room. -
Smart Eco Mode
The SmartEco Mode, which cleverly adjusts the lamp power to maximize power saving by delivering the best contrast and brightness performance using only as much light as needed. -
Eco Blank Mode
The Eco Blank mode allows you to blank the projection. When activated, this special feature dims the lamp power automatically, lowering the total power consumption by 70%.All you need to do is press the "Eco Blank Mode" button on the keypad or the "Blank" button on the remote control. You don't have to worry it's always fully lamp power consumption while you pause movie then leave.
- BenQ W1070 - DLP projector - portable - 3D
- DLP projector - 1080p
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Brightness
- 2000 lumens
- Contrast Ratio
- 10000:1
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours
- Bulb type
- 240 Watt
- Bulb life cycle
- Up to 3500 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL)
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 335 Watt
- 31.2 cm x 24.4 cm x 10.9 cm
- 2.65 kg
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Brightness
- 2000 lumens
- Contrast Ratio
- 10000:1
- Image Size
- 101.6 cm - 596.9 cm
- Throw Ratio
- 1.15 - 1.5:1
- Resolution
- Full HD - Full HD (1920 x 1080)
- 16:9
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 102 kHz
- Bulb type
- 240 Watt
- Bulb life cycle
- OSD Languages
- Danish, Hindi, Hungarian, Czech, Croatian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Japanese, Korean
- ISFccc, ecoFACTS, SmartEco Technology, Eco Blank
Lens
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -20 / +20
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
- 1 x component video input - RCA x 3 , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - mini-phone stereo 3.5 mm , 2 x HDMI - 19 pin HDMI Type A , 1 x serial RS-232 - 9 PIN mini-DIN (management) , 1 x USB - mini-USB Type B (management) , 1 x VGA input - 15 pin D-Sub (DB-15) , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x composite video input - RCA
- Included Accessories
- Wireless remote control
- Voltage Required
- 335 Watt
- Power Consumption Operational (Standby)
- 0.5 Watt
- 31.2 cm
- 24.4 cm
- 10.9 cm
- 2.65 kg
- Sound Emission
- 33 dBA
- Sound Emission (Economic Mode)
- 30 dBA
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
