BenQ 2000 Lumens 1080p Resolution DLP Technology Projector
Quicklinx: 8LJ9WS00 Mfr#: 9H.J7L77.17E
Enjoy 1080p Full-HD image projection up to 200" in the comfort of your living room with the W1070 Home Entertainment Projector. You'll be captivated by brilliant image performance featuring a 10,000:1 contrast ratio and a 2000 lumen brightness. Built-in speakers and easy set-up seal the deal on this user-friendly experience.
  • Full HD 1080p
    Showcase Full-HD content in sharp, 1080p definition and enjoy Blu-ray, video games and HD broadcasting in beautiful, high-contrast quality without downscaling or compression.
  • ISF Certification
    The W1070 is ISF Certified for customization to any room, offering calibration for optimized color performance in both Day and Night modes that can adapt to any room's layout, size and ambient light levels.
  • 3D
    The W1070 supports multiple forms of 3D - including HDMI, Blu-Ray, 3D broadcasting, video games and NVIDIA 3DTV PC connectivity - in 1080p Full-HD for maximum enjoyment. You'll appreciate uninterrupted viewing with no crosstalk thanks to DLP technology and new glasses designed for comfort and peak image quality.
  • Built-in speakers
    Built-in speakers are Plug-and-Play ready, only the power cord and video source connection are needed to prepare the viewing experience.
  • Rich connectivity
    Play from many devices with HDMI x 2 and multiple connectivity options.
  • World-Leading SmartEco technology, green up your living room
    Offering Lower maintenance cost and Optimized Projection Through Dynamic Power Saving Uncompromised brightness, exquisite picture quality and optimized lamp life - BenQ's SmartEco technology has perfected what a DLP projector can do in home entertainment projector. With this special innovation, you are able to save up to 70% of lamp power consumption and lower maintenance costs through dynamic power saving features while bringing an ultra-vivid picture quality in every living room.
  • Smart Eco Mode
    The SmartEco Mode, which cleverly adjusts the lamp power to maximize power saving by delivering the best contrast and brightness performance using only as much light as needed.
  • Eco Blank Mode
    The Eco Blank mode allows you to blank the projection. When activated, this special feature dims the lamp power automatically, lowering the total power consumption by 70%.All you need to do is press the "Eco Blank Mode" button on the keypad or the "Blank" button on the remote control. You don't have to worry it's always fully lamp power consumption while you pause movie then leave.
BenQ W1070 - DLP projector - portable - 3D
DLP projector - 1080p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Brightness
2000 lumens
Contrast Ratio
10000:1
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Bulb type
240 Watt
Bulb life cycle
Up to 3500 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL)
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
335 Watt
31.2 cm x 24.4 cm x 10.9 cm
2.65 kg
3D Capable
Built-in Devices
Speaker
Projector
Brightness
2000 lumens
Contrast Ratio
10000:1
Image Size
101.6 cm - 596.9 cm
Throw Ratio
1.15 - 1.5:1
Resolution
Full HD - Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
120 Hz x 102 kHz
Bulb type
240 Watt
Bulb life cycle
OSD Languages
Danish, Hindi, Hungarian, Czech, Croatian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Japanese, Korean
ISFccc, ecoFACTS, SmartEco Technology, Eco Blank
Lens
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-20 / +20
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
1 x component video input - RCA x 3 , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - mini-phone stereo 3.5 mm , 2 x HDMI - 19 pin HDMI Type A , 1 x serial RS-232 - 9 PIN mini-DIN (management) , 1 x USB - mini-USB Type B (management) , 1 x VGA input - 15 pin D-Sub (DB-15) , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x composite video input - RCA
Wireless remote control
335 Watt
Power Consumption Operational (Standby)
0.5 Watt
31.2 cm
24.4 cm
10.9 cm
2.65 kg
Sound Emission
33 dBA
30 dBA
8LJ9 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
