Ideal for data entry and accounting functions, the YourType wireless keypad is a convenient, time-saving addition to your workspace. This compact wireless keypad adds 28 keys to your Apple wireless keyboard or MacBook, including function keys and document navigation controls.
The keypad pairs wirelessly with your iMac, Mac Pro, or MacBook using Bluetooth technology, so you're free to move it to any convenient and comfortable location within range. This helps you maintain a clean, uncluttered desktop. It also reduces fatigue while typing.
Add command and number keys to apple keyboard
Ideal for data entry and accounting functions, the YourType wireless keypad is a convenient, time-saving addition to your workspace. This compact wireless keypad adds 28 keys to your Apple wireless keyboard or MacBook, including function keys and document navigation controls. -
Wireless Bluetooth connection
The keypad pairs wirelessly with your iMac, Mac Pro, or MacBook using Bluetooth technology, so you're free to move it to any convenient and comfortable location within range. This helps you maintain a clean, uncluttered desktop. It also reduces fatigue while typing. -
Aluminum design is a perfect match
The keypad's aluminum enclosure and low-profile, island-style keys complement the look and feel of your Apple Wireless Keyboard. And like Apple's keyboard, the keys respond quickly when touched.
- Belkin YourType - keypad
- Keypad
- Interface
- Bluetooth
- Keys Qty
- 28
- Designed For
- Apple MacBook Air; MacBook Pro
- Keypad
- Interface
- Bluetooth
Input Device
- Keys Qty
- 28
- AA type
- Installed Qty
- 2
- Required Qty
- 2
- Designed For
- Apple MacBook Air , Apple MacBook Pro
