Advanced performance for video streaming and online gaming
MultiBeam Technology
Belkin's exclusive MultiBeam antenna technology gives you maximum throughput while minimizing dead spots for optimized video streaming from multiple devices, virtually anywhere in your home.
Dual-Band Speed
Get the fastest dual-band speeds for video streaming and online gaming--up to 300Mbps (2.4GHz) + 300Mbps (5GHz).*
1 USB Port
Connect an external hard drive for easy sharing of photos and files, or connect a printer for wireless printing from any computer in your home.
Preset Security
WPS/WPA2 encryption standards and preset security settings get you up and running safely. One-touch Wi-Fi Protected Setup (WPS) securely connects multiple computers and devices with the push of a button.
Easy Setup
Get your secure wireless network up and running in minutes. Just three easy steps, and you're you out of the box and onto the Web.
+4 Apps
Enhance your online activities with Belkin's integrated apps: SELF-HEALING, VIDEO MOVER, PRINT ZONE and MEMORY SAFE™.
*The standard transmission rates--300Mbps (for 2.4GHz), 300Mbps (for 5GHz), 54Mbps, and 11Mbps--are the physical data rates. Actual data throughput will be lower and may depend on the mix of wireless products used.
MultiBeam technology
Belkin's exclusive MultiBeam antenna technology gives you powerful signal strength and maximum coverage, while minimizing dead spots - so you can connect from virtually anywhere in your home. -
Dual-band speed
Get the fastest dual-band speeds for video streaming and online gaming - up to 300Mbps (2.4GHz) + 300Mbps (5GHz). -
1 USB port
Connect an external hard drive for easy sharing of photos and files, or connect a printer for wireless printing from any computer in your home. -
Preset security
WPS/WPA2 encryption standards and preset security settings get you up and running safely. One-touch Wi-Fi Protected Setup (WPS) securely connects multiple computers and devices with the push of a button. -
Easy setup
Get your secure wireless network up and running in minutes. Just three easy steps, and you're you out of the box and onto the Web. -
+4 app
Enhance your online activities with Belkin's integrated apps: Self-Healing, Video Mover, Print Zone and Memory Safe.
- Belkin F9J1102 - wireless router - DSL modem - 802.11a/b/g/n - desktop
- Wireless router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 300 Mbps
- Capacity
- Connection / user qty: 16
- TCP/IP, PPTP, L2TP, IPSec, PPPoE
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- HTTP, HTTPS
- NAT support, Stateful Packet Inspection (SPI), Wi-Fi Protected Setup (WPS), MultiBeam technology
- IEEE 802.11a, IEEE 802.11d, IEEE 802.11g, IEEE 802.11n
- System Requirements
- Apple MacOS X 10.6, Microsoft Windows XP SP3 or later, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits)
- Localisation
- United Kingdom
- 2-year warranty
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 300 Mbps
- Capacity
- Routing Protocol
- Static IP routing
- HTTP, HTTPS
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, 256-bit WPA, WPA2
- Authentication Method
- Radio Service Set ID (SSID)
- Status Indicators
- Status
Communications
- DSL modem
- ADSL
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL - RJ-11 , USB 2.0: 1 x 4 pin USB Type A
Aerial
- Aerial
- Internal
- Power Device
- External power adapter
- Cables Included
- 1 x network cable , 1 x modem cable
- Localisation
- United Kingdom
- Software Included
- Drivers & Utilities, Self-Healing, Memory Safe
- OS Required
- System Requirements Details
- Windows XP/Vista/7 - 1.8 GHz - RAM 512 MB , MacOS X 10.5/10.6 - 1.8 GHz - RAM 512 MB
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
