Belkin Wireless N600 Dualband Router DSL (Cable Line)
Quicklinx: 8LDPWS00 Mfr#: F9K1102uk
Type: Wireless router
Connection Type: DSL (Cable)
Standards: Ethernet, Fast Ethernet, IEEE 802.11a, IEEE 802.11b + 2 more
Speed: 300Mbps
Rackmount or External: External
  • IEEE 802.11n
Hurry, only 1 left in stock!
£39.21 ex VAT
£47.05 inc VAT
Advanced performance for video streaming and online gaming
MultiBeam Technology
Belkin's exclusive MultiBeam antenna technology gives you maximum throughput while minimizing dead spots for optimized video streaming from multiple devices, virtually anywhere in your home.
Dual-Band Speed
Get the fastest dual-band speeds for video streaming and online gaming--up to 300Mbps (2.4GHz) + 300Mbps (5GHz).*
1 USB Port
Connect an external hard drive for easy sharing of photos and files, or connect a printer for wireless printing from any computer in your home.
Preset Security
WPS/WPA2 encryption standards and preset security settings get you up and running safely. One-touch Wi-Fi Protected Setup (WPS) securely connects multiple computers and devices with the push of a button.
Easy Setup
Get your secure wireless network up and running in minutes. Just three easy steps, and you're you out of the box and onto the Web.
+4 Apps
Enhance your online activities with Belkin's integrated apps: SELF-HEALING, VIDEO MOVER, PRINT ZONE and MEMORY SAFE™.
*The standard transmission rates--300Mbps (for 2.4GHz), 300Mbps (for 5GHz), 54Mbps, and 11Mbps--are the physical data rates. Actual data throughput will be lower and may depend on the mix of wireless products used.
  • MultiBeam technology
  • Dual-band speed
    Get fast dual-band speeds for video streaming and online gaming.
  • 1 USB port
  • Preset security
  • Easy setup
    Get your secure wireless network up and running in minutes. Just three easy steps and you're you out of the box and onto the web.
  • Self-healing
    Belkin routers automatically detect and resolve network problems and run routine maintenance scans to give you the clearest wireless channel. If attention is required, a notification will appear right on your screen - no more blinking lights under your desk.
  • Video mover
    Watch videos from your movie library on your TV - wirelessly. Connect an external hard drive to the router and move stored videos to your TV through devices like a Blu-ray player, Xbox 360, and PlayStation 3.
  • Print zone
    Printing has never been easier. Just connect any compatible printer to your Belkin router, and print from any computer in the house - wirelessly.
  • MEMORY SAFE
    Digital files are time-consuming to keep track of and vulnerable to loss. You can automatically back up precious photos and important files to an external hard drive attached to the router - you choose what to back up.
Belkin F9K1102 - wireless router - 802.11a/b/g/n - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
300 Mbps
Virtual interfaces (VLANs): 16
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, PPPoE
Routing Protocol
Static IP routing
Remote Management Protocol
HTTP, HTTPS
NAT support, Stateful Packet Inspection (SPI), Wi-Fi Protected Setup (WPS)
IEEE 802.11a, IEEE 802.11d, IEEE 802.11g, IEEE 802.11n
Microsoft Certification
Compatible with Windows 7
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
300 Mbps
Routing Protocol
Static IP routing
HTTP, HTTPS
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA2-PSK
Authentication Method
Radio Service Set ID (SSID)
Status Indicators
Status
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
Internal
External power adapter
1 x network cable
Software Included
Drivers & Utilities
10 - 85% (non-condensing)
Network Adaptors (1)
Expand your network
8LDP C2G Trulink® USB to Gigabit Ethernet Adapter In Stock £23.94
Other bundles (6)
8LDP C2G 2m USB 2.0 A/B Cable - Black In Stock £2.00
8LDP C2G 5m USB 2.0 A/B Cable - Black In Stock £5.14
8LDP C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.89
8LDP C2G 12m USB 2.0 A/A Active Extension Cable In Stock £17.13
8LDP C2G USB Superbooster Extender Kit In Stock £38.72
8LDP C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
Standards: Ethernet
Standards: Fast Ethernet
Standards: IEEE 802.11a
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Speed: 300Mbps
Brand: Belkin
Price Range Ex VAT: 0 - 50
