Advanced performance for video streaming and online gaming
MultiBeam Technology
Belkin's exclusive MultiBeam antenna technology gives you maximum throughput while minimizing dead spots for optimized video streaming from multiple devices, virtually anywhere in your home.
Dual-Band Speed
Get the fastest dual-band speeds for video streaming and online gaming--up to 300Mbps (2.4GHz) + 300Mbps (5GHz).*
1 USB Port
Connect an external hard drive for easy sharing of photos and files, or connect a printer for wireless printing from any computer in your home.
Preset Security
WPS/WPA2 encryption standards and preset security settings get you up and running safely. One-touch Wi-Fi Protected Setup (WPS) securely connects multiple computers and devices with the push of a button.
Easy Setup
Get your secure wireless network up and running in minutes. Just three easy steps, and you're you out of the box and onto the Web.
+4 Apps
Enhance your online activities with Belkin's integrated apps: SELF-HEALING, VIDEO MOVER, PRINT ZONE and MEMORY SAFE™.
*The standard transmission rates--300Mbps (for 2.4GHz), 300Mbps (for 5GHz), 54Mbps, and 11Mbps--are the physical data rates. Actual data throughput will be lower and may depend on the mix of wireless products used.
MultiBeam technology
Belkin's exclusive MultiBeam antenna technology gives you maximum throughput while minimizing dead spots for optimized video streaming from multiple devices, virtually anywhere in your home. -
Dual-band speed
Get fast dual-band speeds for video streaming and online gaming. -
1 USB port
Connect an external hard drive for easy sharing of photos and files, or connect a printer for wireless printing from any computer in your home. -
Preset security
WPS/WPA2 encryption standards and preset security settings get you up and running safely. One-touch Wi-Fi Protected Setup (WPS) securely connects multiple computers and devices with the push of a button. -
Easy setup
Get your secure wireless network up and running in minutes. Just three easy steps and you're you out of the box and onto the web. -
Self-healing
Belkin routers automatically detect and resolve network problems and run routine maintenance scans to give you the clearest wireless channel. If attention is required, a notification will appear right on your screen - no more blinking lights under your desk. -
Video mover
Watch videos from your movie library on your TV - wirelessly. Connect an external hard drive to the router and move stored videos to your TV through devices like a Blu-ray player, Xbox 360, and PlayStation 3. -
Print zone
Printing has never been easier. Just connect any compatible printer to your Belkin router, and print from any computer in the house - wirelessly. -
MEMORY SAFE
Digital files are time-consuming to keep track of and vulnerable to loss. You can automatically back up precious photos and important files to an external hard drive attached to the router - you choose what to back up.
- Belkin F9K1102 - wireless router - 802.11a/b/g/n - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 300 Mbps
- Capacity
- Virtual interfaces (VLANs): 16
- TCP/IP, PPTP, L2TP, IPSec, PPPoE
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- HTTP, HTTPS
- NAT support, Stateful Packet Inspection (SPI), Wi-Fi Protected Setup (WPS)
- IEEE 802.11a, IEEE 802.11d, IEEE 802.11g, IEEE 802.11n
- Microsoft Certification
- Compatible with Windows 7
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 300 Mbps
- Capacity
- Routing Protocol
- Static IP routing
- HTTP, HTTPS
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA2-PSK
- Authentication Method
- Radio Service Set ID (SSID)
- Status Indicators
- Status
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
- Aerial
- Internal
- Power Device
- External power adapter
- Cables Included
- 1 x network cable
- Software Included
- Drivers & Utilities
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
Network Adaptors (1)
Expand your network
C2G Trulink® USB to Gigabit Ethernet Adapter | In Stock | £23.38 |
Other bundles (7)
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £3.11 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £4.51 |
C2G 5m USB 2.0 A Male to A Female Active Extension Cable | In Stock | £12.76 |
C2G 4-Port USB 2.0 Aluminum Hub | In Stock | £19.32 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £16.73 |
C2G USB Superbooster Extender Kit | In Stock | £37.81 |
C2G USB to HDMI Adapter with Audio Up To 1080p | In Stock | £42.30 |
