Belkin Wireless N300 USB Adapter
Quicklinx: 8LDGWS00 Mfr#: F7D2102az
  • IEEE 802.11n
Connect your netbook or laptop to your wireless network.
Compact Design
The compact design of the Surf+ N300 USB Wireless Micro Adapter makes it easy to connect to your laptop or netbook and go. It's so small you can easily leave it connected to your computer.
Easy Setup
Connect your computer to your modem or router without cables. Just plug the adapter into your computer's USB port and insert the setup CD, and you're ready to connect to the Internet from anywhere in your home.
Speed
Get wireless speeds ideal for surfing, emailing and instant messaging--up to 300Mbps.*
Simple Security
WEP and WPA/WPA2 security protocols and Wi-Fi Protected Setup (WPS) let you configure and secure your connection.
Backward-Compatible
Backward-compatible with 802.11g devices at 54 Mbps and 802.11b products at 11 Mbps, the Surf+ N300 USB Wireless Micro Adapter can connect to older wireless networks and hotspots as well as newer 802.11n networks and wireless-N devices that offer increased range and speed.
*The standard transmission rates--300Mbps, 54Mbps, and 11Mbps--are the physical data rates. Actual data throughput will be lower.
  • Compact design
    The compact design of the N300 micro wireless USB adapter makes it easy to connect to your laptop or netbook and go. It's so small you can easily leave it connected to your computer.
  • Easy setup
  • Push-button security
    WEP and WPA/WPA2 security protocols and Wi-Fi Protected Setup (WPS) let you configure and enable security features with the push of a button.
  • Backward-compatible
    Backward-compatible with 802.11 a/g devices at 54 Mbps and 802.11b products at 11 Mbps, the N300 micro wireless USB adapter can connect to older wireless networks and hotspots as well as 802.11n networks and wireless-N devices that offer increased range and speed.
Belkin SURF N300 USB Wireless N Micro Adapter - network adapter - USB 2.0
Network adapter
External
Interface (Bus) Type
USB 2.0
1.8 cm x 3.6 cm
10 g
802.11b/g/n
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows XP SP3 or later
Network adapter
External
USB 2.0
Wireless
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
WPS
Aerial
Antenna
Internal
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
Software Included
Drivers & Utilities
1.8 cm
3.6 cm
10 g
60 °C
0 - 90% (non-condensing)
