Connecting the Enhanced Wireless Router to your cable or ADSL modem lets you share your broadband Internet account with all your networked computers. Now you can quickly and efficiently exchange documents, share resources and stream digital music throughout your network.
For the most reliable network performance, and to achieve coverage ideal for a home or office pair this router with the Belkin Enhanced USB adapter. The combination provides a wireless experience perfect for sharing your Internet connection, surfing the web and demanding network applications.
- Belkin F6D4630-4 - wireless router - DSL modem - Wi-Fi - desktop
- Wireless router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL, ADSL2, ADSL2+
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft 2.0)
- Data Transfer Rate
- 150 Mbps
- TCP/IP, PPTP, IPSec
- Remote Management Protocol
- HTTP
- WPS
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft 2.0)
- System Requirements
- Apple MacOS X 10.x, Microsoft Windows Vista / 2000 / XP
- Localisation
- United Kingdom
- Limited lifetime warranty
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- 150 Mbps
- Max Range Open Space
- 300 m
- HTTP
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, 256-bit WPA, WPA, WPA2
- Authentication Method
- Radio Service Set ID (SSID)
- WPS
Communications
- DSL modem
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL2+ - RJ-11
Aerial
- Aerial
- External detachable
- Power Device
- External power adapter
- Cables Included
- 1 x network cable
- Localisation
- United Kingdom
- OS Required
- Limited warranty - lifetime
