Your basket is empty
Belkin VGA to DVI Smart Cable  6'
Quicklinx: B5ZCWS00 Mfr#: F1D9009B06
Belkin Smart Cables connect between the Desktop Computer and the KVM. Once connected, the cable converts the video signal (VGA or DVI) from the PC to a compatible signal for the KVM. The KVM is now able to support mix platform environments. Belkin smart cables are fully compatible with Belkin KVMs.
The Belkin Smart VGA to DVI-D Cable connects to Belkin Advanced Secure DVI-I and Secure DVI-D KVM Switches and provides multi-platform support for desktop computers with an analog connection (VGA). It also converts analog (VGA) signals to digital in order to support Advanced Secure DVI-I and Secure DVI-D KVMs in conjunction with a digital (DVI-D) monitor.
Belkin Secure KVM Cable Kit - video / USB cable - 1.8 m - B2B
Video / USB cable
Length
1.8 m
Connectors
15 pin HD D-Sub (HD-15) - male , 4 pin USB Type A - male
Connectors (Second End)
24+1 pin digital DVI - male , 4 pin USB Type B - male
Manufacturer Selling Program
Belkin B2B
P/N: F1DN102DEA, F1DN104B-3EA, F1DN104DEA, F1DN104W-3
Video / USB cable
Length
1.8 m
Connectors
Belkin B2B
