The USB-C to VGA Adapter is 15cm of finely tuned USB-C cable designed and tested by Belkin, allowing a seamless connection from any compatible USB-C device to your legacy projector, TV or monitor. Whether it's sharing content at work, or transitioning new tech into your home office, it's the ideal solution for your USB-C enabled device.
- Belkin adapter - VGA / USB - 15 cm
- Cable
- Adapter - VGA / USB
- Length
- 15 cm
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- HD-15 (VGA) - female
- DisplayPort Alternate Mode support
- Works With Chromebook
- 2-year warranty
- Cable Type
- Adapter
- Interface Supported
- VGA / USB
- Length
- 15 cm
Adapters & Converters
- OS Required
- Apple MacOS X, Google Chrome OS, Windows 10
- Connector
- 15 pin HD D-Sub (HD-15) - female
- Limited warranty - 2 years
