Your basket is empty
Belkin USB AC Wall Plug Charger Micro-USB Charge for Smartphones
Quicklinx: BB1SWS00 Mfr#: F8M667uk04-WHT
Charge your mobile device at the fastest possible speed with this charger that works in any power outlet. Comes with a 4-foot micro USB ChargeSync cable for connecting to your desktop or laptop computer.
Belkin Tablet Charger - power adapter
Power adapter
Output Connector Type
USB - on cable: Micro-USB
Cables
Micro-USB to USB cable - 1.22 m
Power adapter
Enclosure Colour
White
Input Connectors
Power BS 1363
Output connectors
4 pin USB Type A
Power Provided
10 Watt
Detachable Cable Connector Type
Micro-USB Type B
Max Electric Current
2.1 A
BB1S C2G 2m USB 2.0 A/B Cable - Black In Stock £3.02
BB1S C2G 5m USB 2.0 A/B Cable - Black In Stock £4.24
BB1S C2G 2-Port USB 2.0 Manual Switch In Stock £16.25
BB1S C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £11.34
BB1S C2G 4-Port USB 2.0 Aluminum Hub In Stock £25.75
BB1S C2G 12m USB 2.0 A/A Active Extension Cable In Stock £14.89
