The Belkin USB-C to Micro-B cable allows you to connect Micro-B devices to a USB-C enabled device for great levels of speed and efficiency. Experience up to 10 Gbps transfer rates, up to 20X faster than USB 2.0 (480Mbps), 12x faster than FireWire 800, and 2X faster than USB 3.0 (5Gbps). You will be amazed at the difference USB 3.1 makes.
USB 3.1
USB 3.1 SuperSpeed+ offers a high level of connectivity. Transfer data at incredible speeds, charge other devices, and even power mobile devices - all with just one USB-C cable. -
Faster data transfer
Transfer data at up to 10Gbps with improved cables and connectors. USB 3.1 offers faster rates than ever before. Fast enough to transfer a year's worth of music in 10 minutes or an entire HD movie in just 30 seconds. -
Power & charge other devices
This USB-C cable supports up to 3A of power output for charging Micro-B devices. -
Reversible type-c connector
Never worry about which way to plug in again. USB-C is a user-friendly reversible connector that allows you to connect your cable to your device in any direction.
- Belkin - USB-C cable - 24 pin USB-C to Micro-USB Type B - 91.4 cm
- USB-C cable
- Sync and charge, Power Delivery (PD) technology, 10 Gbps data rate
- Length
- 91.4 cm
- Connector
- 24 pin USB-C - male - reversible
- Connector (Second End)
- 10 pin Micro-USB Type B - male
- Rated Current
- 3 A
- USB 3.1
- Black
- USB-C cable
- Rated Current
- 3 A
- Length
- 91.4 cm
- Black
- Connector
- USB 3.1, USB-IF
