Connect your Ultrabook or thin-and-light laptop to all your office peripherals with a single SuperSpeed USB 3.0 cable.
Mobile users often do without the advantages of external monitors, full-size keyboards, and other desktop peripherals because of the hassle involved in connecting, disconnecting, and reconnecting every device, every time they leave their desk or return to it.
Belkin offers the best of two worlds with the USB 3.0 dual video docking stand for Ultrabook - the freedom and convenience of mobility with the comfort and functionality of a fully equipped office. The video docking stand provides quick, easy access to multiple peripherals through a single USB 3.0 cable: external displays, keyboard and mouse, printer, network, and more. Configure your workspace just the way you like it, then come and go as you please.
Eliminate clutter with built-in Ethernet, display, and USB ports as well as integrated cable management, for an organized workspace that's always ready when you want it.
Improve productivity when you multiply your screen space with one or two high-resolution external monitors. The video stand features a stable platform designed to hold your laptop screen comfortably at eye level and even with other displays.
Simplify mobility with a versatile docking station designed for mixed platforms and multiple users, ideal for visiting professionals, contractors, and "hot desk" environments.
Easy connectivity
Connect to your network and all your desktop peripherals with just a single USB 3.0 cable. -
Broad compatibility
Use with any USB 3.0 - equipped Ultrabook. -
Extra ports
Multiply your connectivity with four available USB ports as well as Ethernet and dual display options. -
Multiple displays
Connect one or two external high-resolution displays to improve usability and productivity. -
Optimized workspace
Control cable clutter and keep desktop accessories organized. -
Charging station
Recharge smartphones and tablets quickly with the fast-charging 2.1 A USB 3.0 port.
- Belkin USB 3.0 Dual Video Docking Stand for Ultrabooks - docking station - USB
- Product Type
- Docking station
- Docking Interface
- USB
- Power
- Power Provided
- Product Type
- Docking station
- 2 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x SuperSpeed USB 3.0 - 9 pin USB Type B , 2 x USB 2.0 - 4 pin USB Type A , 1 x network - Ethernet - RJ-45 , 1 x display / video - DVI-Digital (dual link) - 18+1 pin digital DVI (Single-Link) , 1 x display / video - DisplayPort - 20 pin DisplayPort , 1 x audio - line-out/microphone - mini-phone 3.5 mm
