Belkin USB 2.0,TYPE C-USB A, 480MBPS, 3 amp, 6ft , Black
Quicklinx: BG9HWS00 Mfr#: F2CU032bt06-BLK
Charge and sync your Samsung Galaxy devices quickly and safely, using just one cable. Simply plug the USB end directly into any USB port to stay connected while you're at home, at work, or on the road.
Use the MiXiT UP Micro-USB to USB ChargeSync cable to charge and sync your Samsung at the fastest possible speed. The small, durable micro USB connector also works with most smartphones and tablets with a micro USB port.
The MiXiT UP ChargeSync cable plugs into any USB 2.0 port, so you can use it virtually anywhere. Connect to your laptop to charge and sync, use your own wall charger to charge from the wall, or plug into a car charger and charge on the road.
  • Charge and sync your smartphone or tablet
    The Belkin MIXIT? USB-A to USB-C charge cable lets you charge your USB-C smartphone or tablet as well as sync your photos, music and data to your existing laptop at high transfer speeds.
  • Power & charge other devices
    This MIXIT? USB-C cable supports up to 3 A of power output and can be used for charging and powering USB-C enabled devices.
  • Reversible USB-C connector
    Never worry about which way to plug in again. USB-C is user-friendly reversible connector that allows you to connect your cable to your device in any direction.
Belkin MIXIT 2.0 USB-A to USB-C Charge Cable - USB-C cable - USB to 24 pin USB-C - 1.8 m
USB-C cable
Sync and charge
Length
1.8 m
Connector
4 pin USB Type A - male
Connector (Second End)
24 pin USB-C - male - reversible
Rated Current
3 A
USB / USB 2.0
USB-C cable
Rated Current
3 A
Sync and charge
Length
1.8 m
Connector
USB / USB 2.0, USB-IF
