Your basket is empty
Belkin USB 2.0 4 Port Mobile Hub Black
Quicklinx: BQLDWS00 Mfr#: F5U404PUKBLK
The Hi-Speed USB 2.0 4-Port Mobile Hub provides four downstream USB ports that offer easy plug-and-play connectivity to your USB 1.1 and USB 2.0 devices. It lets you easily connect up to four of your USB 1.1 and 2.0 devices to your computer, such as an iPod or other MP3 player, digital camera, or printer. Its compact size makes it a perfect travel tool, designed to easily tuck into the pockets of a laptop bag.
Belkin Hi-Speed USB 2.0 4-Port Mobile Hub - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x USB 2.0
United Kingdom
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
4 x USB 2.0
4 x USB 2.0 Type A , 1 x USB 2.0
United Kingdom
BQLD C2G 2m USB 2.0 A/B Cable - Black In Stock £3.02
BQLD C2G 5m USB 2.0 A/B Cable - Black In Stock £4.42
BQLD C2G 2-Port USB 2.0 Manual Switch In Stock £16.36
BQLD C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £11.41
BQLD C2G 4-Port USB 2.0 Aluminum Hub In Stock £25.45
BQLD C2G 12m USB 2.0 A/A Active Extension Cable In Stock £14.97
