Charge two devices at once, while on the road. The Belkin Dual Car Charger gives you unlimited play and standby time while in the car, and keeps you and a passenger fully charged wherever you go. The low-profile design fits easily in your dash without getting in the way of your other controls. Rubber grips make it easy to insert and remove the Dual Car Charger, and the blue indicator light ring lets you know the charger is fully plugged in and your device is charging.
- Belkin car power adapter - 2 x USB - 20 Watt
- Product Type
- Car power adapter
- Black
- Output Connector Type
- Total 2: 2 x USB
- Max Electric Current
- 2.1 A
- Power Provided
- 20 Watt
- Power Device Details
- 2 x - 4 pin USB Type A - 2.1 A
- Product Type
- Car power adapter
- Designed For
- Mobile phone
- Enclosure Colour
- Black
- Input Connectors
- Automobile cigarette lighter
- Output connectors
- Total 2: 2 x 4 pin USB Type A
- Power Provided
- 20 Watt
- 2.1 A
- 2 x 4 pin USB Type A - 2.1 A
- LED indicator
