Belkin TrueClear Screen Protector for iPhone 6 (pack of 3)
Quicklinx: B6Z0WS00 Mfr#: F8W526BT3
More than 50 in stock
£1.34 ex VAT
£1.60 inc VAT
TrueClear advanced screen protector for iPhone 6 is the best screen protector available, engineered for strength and clarity and tested to meet optometric standards. The result is a crystal clear screen protector that keeps your screen safe from damage while still giving you an incredible screen experience.
  • Pixel for pixel, clearest protection available
    Patented TrueClear technology allows light to pass through the screen protectors precisely and evenly, giving you a level of sharpness and vibrancy higher than even the leading competitor's high-definition products.
  • Market leader in clarity
    The screen protectors are tested for optical precision and clarity using the same methods optometrists use for eyeglasses. These tests, combined with third-party data, position TrueClear iPhone 6 screen protectors as the market leaders in clarity - the clearest screen protection you can buy.
  • Fast, easy application
    Applying your iPhone 6 screen protector is fast and easy. Start by cleaning your screen with the included cleaning wipe and dust removal film, then peel the overlay from its backing and place it onto your screen. Finish by using the included smoothing card to push away creases and bubbles.
  • Case-compatible
    TrueClear Advanced Screen Protectors fit your iPhone 6's screen perfectly, and are designed to work with any case to give you 360° protection. Strong yet thin and lightweight, the iPhone 6 screen protector provides excellent defense against damage that will help keep your device looking like new.
Belkin TrueClear - screen protector
Screen protector
Intended For
Mobile phone
Protection
Scratch-resistant
Package Content
Screen protector, 3 screen protectors, smoothing card
Apple iPhone 6
Screen protector
Intended For
Mobile phone
Protection
Scratch-resistant
Package Content
Anti-fingerprint, Tru Clear technology, case fit
Lifetime
Apple iPhone 6
Brand: Belkin
Price Range Ex VAT: 0 - 50
