TrueClear InvisiGlass advanced screen protection for iPhone 5 is the best screen protector available, engineered for strength and clarity and tested to meet optometric standards. The result is a crystal clear screen protector that keeps your screen safe from damage while still giving you an incredible screen experience.
InvisiGlass screen protector for iPhone 5
TrueClear InvisiGlass advanced screen protection for iPhone 5 is the best screen protector available, engineered for strength and clarity and tested to meet optometric standards. The result is a crystal clear screen protector that keeps your screen safe from damage while still giving you an incredible screen experience. -
Looks and feels like glass, because it is glass
The advanced iPhone 5 screen protector is made with 100% real, flexible glass, making it 9x stronger than the competition and 2.5x smoother than regular plastic screen protectors. It's also amazingly thin - only 0.2 mm between you and your screen. -
Engineered with FluidFlex technology
A higher molecular density gives the InvisiGlass screen protector its unbelievable strength, and makes it harder for foreign objects, like keys or concrete, to damage it. And thanks to specially engineered FluidFlex technology, the glass screen protector has a unique elasticity that actually absorbs the shock of impact. -
The science behind it
InvisiGlass screen protectors have a uniform molecular structure that preserves the vibrant color, resonance and clarity of your screen with virtually no distortion, so you can enjoy the brilliance of each and every pixel. The concentrated elastic bonding in the breakthrough material eliminates the friction that causes drag, giving you the exact same touch-sensitivity and glide as the naked screen itself. -
Pixel for pixel, clearest protection available
TrueClear technology allows light to pass through the screen protectors precisely and evenly, giving you a level of sharpness and vibrancy higher than even the leading competitor's high-definition products. -
Fast, easy application
Applying your iPhone 5 screen protector is fast and easy. Start by cleaning your screen with the included cleaning wipe and dust removal film, then peel the overlay from its backing and place it onto your screen. Finish by using the included smoothing card to push away creases and bubbles.
- Belkin TrueClear InvisiGlass - screen protector for mobile phone
- Product Type
- Screen protector
- Intended For
- Mobile phone
- Protection
- Scratch-resistant
- Package Content
- Screen protector, dust remover, cleaning wipe
- Thickness
- 0.02 cm
- Limited lifetime warranty
- Product Type
- Screen protector
- Intended For
- Mobile phone
- Protection
- Scratch-resistant
- Package Content
- Thickness
- 0.02 cm
- Flexible
- Replacement - lifetime
