Product
Belkin TrueClear Invisiglass Overlay Flexi Glass for iPhone 6 Plus
Need a Mobile Tariff ??? See Description Below
Quicklinx: 9S2HWS00 Mfr#: F8W613VF
£19.42 ex VAT
£23.30 inc VAT
InvisiGlass advanced screen protection for iPhone 6 Plus is the best screen protector available, engineered for strength and clarity and tested to meet optometric standards. The result is a crystal clear screen protector that keeps your screen safe from damage while still giving you an incredible screen experience.
  • Looks & feels like glass, because it is glass
    This advanced iPhone 6 Plus screen protector is made from 100% real, flexible glass, making it 9x stronger than the competition and 2.5x smoother than regular plastic screen protectors. It's also amazingly thin - only 0.2mm between you and your screen.
  • Engineered with FluidFlex technology
    A higher molecular density gives the InvisiGlass iPhone 6 plus screen protector its unbelievable strength, and makes it harder for foreign objects, like keys or concrete, to damage it. And thanks to specially engineered FluidFlex technology, the glass screen protector has a unique elasticity that actually absorbs the shock of impact.
  • The science behind it
    InvisiGlass screen protectors have a uniform molecular structure that preserves the vibrant color, resonance and clarity of your screen with virtually no distortion, so you can enjoy the brilliance of each and every pixel. The concentrated elastic bonding in the breakthrough material eliminates the friction that causes drag, giving you the exact same touch-sensitivity and glide as the naked screen itself.
  • Pixel for pixel, clearest protection available
    Patented TrueClear technology allows light to pass through these screen protectors precisely and evenly, giving you a level of sharpness and vibrancy higher than even the leading competitor's high-definition products.
  • Market leader in visibility
    These screen protectors are tested for optical precision and clarity using the same methods optometrists use for eyeglasses. These tests, combined with third-party data, position TrueClear iPhone 6 Plus screen protectors as the market leaders in visibility - the clearest screen protection you can buy.
  • Fast, easy application
    Applying your iPhone 6 Plus screen protector is fast and easy. Start by cleaning your screen with the included cleaning wipe and dust removal film, then peel the overlay from its backing and place it onto your screen. Finish by using the included smoothing card to push away creases and bubbles.
  • Case-compatible
    TrueClear advanced screen protectors fit your iPhone 6 Plus' screen perfectly, and are designed to work with any case to give you 360° protection. Strong yet thin and lightweight, this iPhone 6 Plus screen protector provides excellent defense against damage that will help keep your device looking like new.
Belkin TrueClear InvisiGlass - screen protector
Screen protector
Intended for
Mobile phone
Protection
Shockproof, scratch-resistant
Package Content
Screen protector, smoothing card, dust remover, cleaning wipe
Product Material
Glass
Thickness
0.02 cm
Apple iPhone 6 Plus
Screen protector
Intended for
Mobile phone
Protection
Package Content
Product Material
Glass
Thickness
0.02 cm
Flexible, case fit, FluidFlex technology
Replacement - lifetime
Apple iPhone 6 Plus
Brand: Belkin
Price Range Ex VAT: 0 - 50
