Product
Belkin Tri Fold Folio Case for 8" Galaxy Tab 3/4/Pro/S/Note -Purple
Quicklinx: BB2YWS00 Mfr#: F7P338btC01
This versatile case makes it easy to go from watching movies to sending emails in one simple motion. Everything about this design is extremely thoughtful - from the soft inner lining that keeps your screen safe and cushioned, to the durable outer construction, and the cover that folds into a stand. And because you want to keep your tablet lightweight and portable, this case protects without adding bulk.
  • Quality craftsmanship & materials
    The Tri-Fold Cover with Stand is made of durable, lightweight fabric that's super soft to the touch. It's then molded to the shape of your tablet for an incredibly tailored fit. A velvety smooth inner lining keeps your screen safe and cushioned.
  • Cinema viewing angle
    Watching movies and videos on your tablet couldn't be more comfortable. Just fold the cover all the way back, and your tablet's propped up at the perfect angle.
  • Folds into the perfect angle for typing
    The Tri-Fold Cover with Stand also folds into a lower, more ergonomic angle that puts less stress on your wrists when typing on your touchscreen.
Belkin Trifold - flip cover for tablet
Flip cover for tablet
Screen Size Compatibility
8"
Majesty
Samsung Galaxy Tab 3 (8 in), Tab 4 (8 in)
Majesty
Carrying Case
Protective cover
Recommended Use
For tablet
8"
Cover Type
Flip cover
Open Type
Side
Closure Type
Magnetic closure
Soft inner lining, dual-mode positioning, molded
Cover Features
Stand function
