This versatile case makes it easy to go from watching movies to sending emails in one simple motion. Everything about this design is extremely thoughtful - from the soft inner lining that keeps your screen safe and cushioned, to the durable outer construction, and the cover that folds into a stand. And because you want to keep your tablet lightweight and portable, this case protects without adding bulk.
Quality craftsmanship & materials
The Tri-Fold Cover with Stand is made of durable, lightweight fabric that's super soft to the touch. It's then molded to the shape of your tablet for an incredibly tailored fit. A velvety smooth inner lining keeps your screen safe and cushioned. -
Cinema viewing angle
Watching movies and videos on your tablet couldn't be more comfortable. Just fold the cover all the way back, and your tablet's propped up at the perfect angle. -
Folds into the perfect angle for typing
The Tri-Fold Cover with Stand also folds into a lower, more ergonomic angle that puts less stress on your wrists when typing on your touchscreen.
- Belkin Tri-Fold - flip cover for tablet
- Product Type
- Flip cover for tablet
- Screen Size Compatibility
- 10"
- Blue print
- Designed For
- Samsung Galaxy Tab 3 (10.1 in), Tab 4 (10.1 in)
- Blue print
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- 10"
- Cover Type
- Flip cover
- Open Type
- Side
- Closure Type
- Magnetic closure
- Soft inner lining, dual-mode positioning, molded
- Cover Features
- Stand function
- Designed For
