The TriFold iPad Air Cover is designed first and foremost to keep your iPad Air safe and secure. It's got integrated L-shaped corners that are elastic, so they stretch over the corners of your iPad Air to securely hold it in place. Just bend back the corners when you want to remove it.
The Belkin TriFold Cover iPad Air Case is made of durable, lightweight fabric with a luxurious pebble grain texture. It's then molded to the shape of your iPad Air for an incredibly tailored fit. A velvety smooth inner lining keeps your screen safe and cushioned.
Trifold iPad Air case: work, play, protect
The TriFold Cover for iPad Air makes it easy to go from watch movies to sending emails in one simple motion. Everything about this design is extremely thoughtful - from the soft inner lining that keeps your screen safe and cushioned, to the durable outer construction, and the cover that folds into a stand. And because you want to keep your tablet lightweight and portable, this iPad Air case protects without adding bulk. -
Secure fit
The TriFold iPad Air Cover is designed first and foremost to keep your iPad Air safe and secure. It's got integrated L-shaped corners that are elastic, so they stretch over the corners of your iPad Air to securely hold it in place. Just bend back the corners when you want to remove it. -
Quality craftsmanship and materials
The Belkin TriFold Cover iPad Air Case is made of durable, lightweight fabric with a luxurious pebble grain texture. It's then molded to the shape of your iPad Air for an incredibly tailored fit. A velvety smooth inner lining keeps your screen safe and cushioned. -
Cinema viewing angle
Watching movies and videos with the TriFold Cover for iPad Air couldn't be more comfortable. Just fold the three-paneled cover all the way back, and your iPad Air's propped up at the perfect angle. -
Folds into the perfect angle for typing
The TriFold iPad Air Cover also folds into a lower, more ergonomic angle that puts less stress on your wrists when typing on your touchscreen. -
Strap keeps everything in place
The integrated elastic strap on the TriFold Cover iPad Air Case keeps the front cover closed when you're on the go. The same strap can be used to hold the cover back and out of the way while you're using your tablet.
- Belkin Tri-Fold Folio - protective cover for tablet
- Product Type
- Protective cover for tablet
- Rose
- Rose
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- Closure Type
- Closure strap
- Soft inner lining, secure corner grips
- Cover Features
- Stand function
