Belkin Thunderbolt 2 Express Dock with 1m Thunderbolt Cable
Quicklinx: 9Y7GWS00 Mfr#: F4U085VF
With the Belkin Thunderbolt 2 Express Dock HD, you can connect up to 8 devices (including dual displays) to your powerful Ultrabook, laptop or desktop and take full advantage of Thunderbolt 2 data transfer speeds and 4K cinema resolution.
  • Transfer Terabytes of files in half the time
    The original Thunderbolt Express Dock transfers files at an incredible 10 Gbps. The Thunderbolt 2 technology inside the Belkin Thunderbolt 2 Express Dock HD allows you to transfer at twice that speed - an unprecedented 20 Gbps. That's 4x faster than USB 3.0 and a whopping 25x times faster than Firewire 800. With the Belkin Thunderbolt 2 Express Dock HD, your need for speed has been satisfied.
  • Supports dual displays & 4K cinema resolution
    Imagine connecting two displays to your laptop. Now imagine one of those displays boasting an eye-popping 4K cinema resolution. With the Belkin Thunderbolt 2 Express Dock HD, you can make the display setup of your dreams a reality.
  • Daisy chain additional Thunderbolt devices
    Not only can you connect 8 devices directly to your Belkin Thunderbolt 2 Express Dock HD, but you can continue to add up to 4 additional (5 total) Thunderbolt devices by daisy chaining them together. The configuration potential is virtually limitless, allowing you to customize your setup exactly to your needs and specifications.
Belkin Thunderbolt 2 Express Dock HD - docking station - 2 x Mini DP
Docking station
Docking Interface
Thunderbolt
Video Interfaces
2 x Mini DP
Brushed aluminum
Gigabit Ethernet
Power adapter
Docking station
Enclosure Colour
Brushed aluminum
Gigabit Ethernet
3 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-TX - RJ-45 , 2 x Thunderbolt 2 - Mini DisplayPort , 1 x audio - line-out - mini-phone stereo 3.5 mm , 1 x microphone - input - mini-phone 3.5 mm , 1 x display / video - 19 pin HDMI Type A
1 x Thunderbolt cable - external - 1 m
Power adapter
Microsoft Windows 7 / Windows 8, Apple MacOS X 10.9 or later
9Y7G C2G 2m USB 2.0 A/B Cable - Black In Stock £2.00
9Y7G C2G 5m USB 2.0 A/B Cable - Black In Stock £5.15
9Y7G C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £13.16
9Y7G C2G 12m USB 2.0 A/A Active Extension Cable In Stock £17.24
9Y7G C2G USB Superbooster Extender Kit In Stock £38.96
9Y7G C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
