Belkin Tempered Glass Screen Protector for iPhone 5/5s/5c and SE
Quicklinx: D2W0WS00 Mfr#: F8W719vf
Three times stronger than plastic, and engineered to be stronger than regular glass, Tempered Glass provides resilient, hard-wearing protection for your phone screen. Engineered from real glass, it retains the smooth glide and tactile experience of the screen, and is tested extensively to deliver the brightness, sharpness and clarity you expect from your iPhone. Easy Align stickers deliver a simple and precise self-installation process, for an even edge-to-edge application for maximum protection.
Tempered glass provides multi-level protection for your screen, from surface-level damage such as scratches and scuffs, to deeper level protection against damage from drops and impacts. Smooth, polished edges and flat surface coverage provide screen protection that is hard-wearing and long-lasting.
  • Hard as steel, clear as glass
  • Total protection
  • Visible clarity
    Belkin screen protectors are extensively tested using optometric standards. Designed and engineered from high quality, durable Japanese glass delivers the brightness, sharpness and detail you expect from your phone screen. The result is a crystal clear protective layer that provides the same visual experience as the device itself.
  • The feel of glass
    Glass composition gives the screen protector a tactile response and feedback just like your device. What's more, it has been engineered with fingerprint and oil resistance to help keep the screen feeling clean, and looking clear.
Belkin - screen protector for mobile phone
Screen protector - glass
Intended For
Mobile phone
Protection
Scratch-resistant, impact protection, oil-proof, fingerprint-proof
Package Content
Cleaning cloth, screen protector, dust removal sticker, alignment tool
Product Material
Tempered glass
Intended For
Mobile phone
Protection
Package Content
Product Material
Tempered glass
