Belkin Store & Charge Go - Base + Fixed Dividers
Quicklinx: D3YTWS00 Mfr#: B2B141uk
Store and Charge Go (with fixed slots) is the ideal solution to store and charge multiple devices safely and conveniently. Charge a few devices at the same time while housing all charging cables neatly within the base. The fixed dividers are sturdy and offer a storage solution for laptops, tablets and more. Save valuable classroom real estate by safely affixing the Store and Charge Go to a desk or wall.
  • Multi-device compatible
    Able to house a few mobile devices, Store and Charge Go accommodates laptops and tablets with or without cases. This means simultaneous charging for different devices, from different brands, using different charging connectors - with the added bonus, that the devices will slot in seamlessly.
  • Cost-efficient
    With so many features built-in, Store and Charge Go offers a high-value solution, that delivers a low cost per device - essential for today's cost-sensitive classrooms. The simple, effective and scalable design keeps installation and setup costs minimal and requires little to no maintenance on a day-to-day basis.
  • AC configuration
    The AC configuration combines a metal-case, surge-protected power source with wide-spaced outlets and an on/off switch.
Belkin Store and Charge Go with fixed dividers - charging stand
Charging stand - external
United Kingdom
Power supply
32.83 cm x 30.3 cm
United Kingdom
Power supply
Equipment Protection Value
10000 British Pounds
Surge protection, cable management
32.83 cm
30.3 cm
