Your basket is empty
Belkin Standalone Universal Bluetooth Keybaord
Quicklinx: BB4JWS00 Mfr#: F5L175eaBLK
The ultra-versatile Mobile Wireless Keyboard is the most comfortable way to use your mobile devices. iOS and Android compatible, wirelessly pair any two smartphones and/or tablets for quick and easy toggling between devices. With a unique kickstand design, it's perfect for typing on the go. Plus the kickstand case acts as a protective cover when closed so your keyboard stays safe inside a backpack or handbag. Never choose between your tablet and smartphone again. Now you can wirelessly pair up to two devices at the same time with a Bluetooth Smart keyboard. In fact, any Bluetooth 4.0 enabled device can be paired with the Mobile Wireless Keyboard. So when you're typing an email and get a text on your phone, you can toggle over, respond and get back to emailing without skipping a beat. Never worry about your devices shifting or slipping again, even when you're typing on your lap. The integrated kickstand keeps them securely in place and adjusts for two viewing angles. Large well-spaced TruType keys provide a laptop-like typing experience, helping you minimize errors and increase typing speed. This makes emails, word processing, messaging, and other typing-intensive activities so much easier. Plus built-in shortcut keys offer a quick way to control media and eliminate unnecessary keystrokes. Lightweight and ultra-slim construction makes this the ideal travel accessory. Fits easily in briefcases, handbags, and backpack. The built-in rechargeable battery runs for up to 160 hours between charges and up to 1,900 hours (or 6 months) when in standby mode. When you do need to charge it, the included USB-to-micro-USB cable makes charging easy. There's no need for an on/ off switch. The keyboard turns on when you open the kickstand case and off again when you close it for ease of use and to maintain battery life. Plus the kickstand has magnetic closure so it won't come a part in backpacks or handbags.
Belkin Mobile - keyboard
Keyboard
Bluetooth
TruType keys, magnet closure, Bluetooth 4.0 compatible, adjustable angle stand, pair up to 2 bluetooth devices
Keyboard
Bluetooth
Input Device
1 x micro-USB to USB cable - 1 m
