The high-performance Sport-Fit Galaxy S6 Armband doesn't just protect your phone while you're exercising - it's also incredibly comfortable to wear. The secure fit and slim design stays out of your way, so you forget you're even wearing it. Now you can concentrate on your workout, not your device.
Slim & stylish
The Sport-Fit Armband for Galaxy S6 is made of a stretchy neoprene material that's breathable and hand-washable. It fits snug against your arm to give you full access to your screen without adding extra bulk. Reflective fabric accents keep you safe and visible to others. -
Access to buttons & ports
Belkin Sport-Fit Galaxy S6 Armband is designed so that the home button and headphone port are fully accessible. You can quickly and easily operate your touchscreen and plug in your headphones while keeping your Galaxy S6 inside your armband and on your arm.
- Belkin Sport-Fit Armband - arm pack for mobile phone
- Product Type
- Arm pack for mobile phone
- Material
- Neoprene
- Blacktop
- Designed For
- Samsung Galaxy S6
- Material
- Neoprene
- Blacktop
Carrying Case
- Arm pack
- Recommended Use
- For mobile phone
- Washable
- Carrying Strap
- Arm band
- Adjustable straps, clear screen protector, reflective elements
- Designed For
- Samsung Galaxy S6
