Belkin Sport-Fit Armband for iPhone 6 - Pink
NEED A MOBILE TARIFF ??? SEE DESCRIPTION BELOW
Quicklinx: 9S2BWS00 Mfr#: F8W500BTC01
The high-performance Sport-Fit iPhone Armband doesn't just protect your phone while you're exercising - it's also incredibly comfortable to wear. The secure fit and slim design stays out of your way, so you forget you're even wearing it. Now you can concentrate on your workout, not your device.
  • iPhone Armband: engineered for the perfect fit
  • Slim & stylish
    The Sport-Fit Armband for iPhone is made of a stretchy neoprene material that's breathable and hand-washable. It fits snug against your arm to give you full access to your screen without adding extra bulk.
  • Access to buttons & ports
    The Sport-Fit iPhone Armband is designed so that the home button and headphone port are fully accessible. You can quickly and easily operate your touchscreen and plug in your headphones while keeping your iPhone inside your armband and on your arm.
Belkin Sport-Fit Armband - arm pack for mobile phone
Arm pack for mobile phone
Material
Neoprene
Material
Neoprene
Carrying Case
Arm pack
Recommended Use
For mobile phone
Washable
Carrying Strap
Arm band
Adjustable hand strap
