The high-performance Sport-Fit iPhone 6 Armband doesn't just protect your phone while you're exercising - it's also incredibly comfortable to wear. The secure fit and slim design stays out of your way, so you forget you're even wearing it. Now you can concentrate on your workout, not your device.
The Sport-Fit Armband for iPhone 6 is made of a stretchy neoprene material that's breathable and hand-washable. It fits snug against your arm to give you full access to your screen without adding extra bulk.
The Sport-Fit iPhone Armband 6 is designed so that the home button and headphone port are fully accessible. You can quickly and easily operate your touchscreen and plug in your headphones while keeping your iPhone 6 inside your armband and on your arm.
iPhone 6 armband: engineered for the perfect fit
The high-performance Sport-Fit iPhone 6 Armband doesn't just protect your phone while you're exercising - it's also incredibly comfortable to wear. The secure fit and slim design stays out of your way, so you forget you're even wearing it. Now you can concentrate on your workout, not your device. -
Slim and stylish
The Sport-Fit Armband for iPhone 6 is made of a stretchy neoprene material that's breathable and hand-washable. It fits snug against your arm to give you full access to your screen without adding extra bulk. -
Access to buttons and ports
- Belkin Sport-Fit Armband - arm pack for mobile phone
- Product Type
- Arm pack for mobile phone
- Material
- Neoprene
- Blacktop, overcast
- Material
- Neoprene
Carrying Case
- Arm pack
- Recommended Use
- For mobile phone
- Washable
- Carrying Strap
- Arm band
- Adjustable hand strap
