Belkin Snap Shield for MacBook Air (11-Inch Case)
Quicklinx: D2W7WS00 Mfr#: B2A080-C00
Snap Shield is a fast and simple way to protect MacBooks and Chromebooks in the classroom. A customized fit ensures installation is easy, and requires little set up and maintenance after application. The two-part, slim-fit case offers scratch protection for devices, top and bottom, and works seamlessly with convertible or touchscreen models. Retractable feet on the bottom of the case provide adjustable keyboard angles to make typing easy.
Belkin Snap Shield for MacBook Air (11-inch Case) - notebook cover
Notebook cover
Translucent
Product Material
Polycarbonate
Notebook Compatibility
11"
Scratch-proof, impact resistant, built-in stand
Notebook cover
Product Material
Polycarbonate
11"
Translucent
