Belkin Snap Shield for 11" HP G2, G3, G4 Chromebook
Quicklinx: D3YYWS00 Mfr#: B2A082-C00
Device Type: Laptop
Type: Case
Device Screen Size: 11"
Colour: Transparent
£31.88 ex VAT
£38.25 inc VAT
Snap Shield is a fast and simple way to protect MacBooks and Chromebooks in the classroom. A customized fit ensures installation is easy, and requires little set up and maintenance after application. The two-part, slim-fit case offers scratch protection for devices, top and bottom, and works seamlessly with convertible or touchscreen models. Retractable feet on the bottom of the case provide adjustable keyboard angles to make typing easy.
Belkin Snap Shield for HP G4 (11-inch Case) notebook cover
Notebook cover
Translucent
Product Material
Polycarbonate
Notebook Compatibility
11"
Scratch-proof, impact resistant, built-in stand
HP Chromebook 11 G4
Notebook cover
Product Material
Polycarbonate
11"
Translucent
HP Chromebook 11 G4
Device Type: Laptop
Type: Case
Colour: Transparent
Brand: Belkin
