Safely charge your smartphone, tablet, or power bank faster with the portable BOOST?CHARGE 12W USB-A wall charger. At home, at the office, or even on the go, this compact wall charger can be used anywhere, giving you a faster charge than standard 5W wall chargers.
The portable 12W charger + cable solution
Safely charge your smartphone, tablet, or power bank faster with the portable BOOST?CHARGE 12W USB-A wall charger. At home, at the office, or even on the go, this compact wall charger can be used anywhere, giving you a faster charge than standard 5W wall chargers. -
Portable and powerful
This 12W charger is lightweight, compact, and ideal for travel when you're on the move. Conveniently sized so you can toss it in your bag, pocket, or suitcase when on the go.
- Belkin BoostCharge power adapter - USB - 12 Watt
- Product Type
- Power adapter
- White
- Output Connector Type
- USB
- Power Provided
- 12 Watt
- 2-year warranty
- Product Type
- Power adapter
- Designed For
- Tablet, mobile phone
- Enclosure Colour
- White
- Output connectors
- 4 pin USB Type A
- Power Provided
- 12 Watt
- Equipment Protection Value
- 1500 British Pounds
- Limited warranty - 2 years
