Belkin SheerForce Elite Protective Case for iPhone X/XS - Sliver
Quicklinx: DXSXWS00 Mfr#: F8W868btC01
Device Type: iPhone X
Type: Case
£31.88 ex VAT
£38.25 inc VAT
The durable SheerForce Elite protective case is easy to grip and improves drop performance. Constructed of a UV-resistant material, your case maintains its clarity, even when exposed to the sun.
  • Strength and resilience
    The polycarbonate construction combines aspects of plastic and rubber to provide strength and shock-absorption simultaneously.
  • Improved drop performance
    Engineered to successfully disperse impacts throughout the case and preserve the phone within. A unique molecular structure provides improved drop performance.
  • Scratch-resistant case
    Add a protective layer to defend against keys, debris and other items that can cause cosmetic damage to your iPhone.
  • Everything counts
    Even the edges of the case have been thoughtfully designed to prevent damage to your screen. A slightly raised edge provides a space between your screen and the surface when laying the phone screen down.
  • Ready for anything
    These cases withstand drops and abrasive components, ensuring advanced protection for your iPhone. They maintain their clarity and custom fit when exposed to extreme temperatures, high humidity, UV rays, solvents and heavy use over the lifetime of your phone.
  • All access
    Access points have been designed around ports and speakers, allowing full access to your phone's features. Buttons maintain "push+click" tactility while safely covered. Adjust volume, plug in headphones, connect charging cables and dock your iPhone X without removing the case.
Belkin SheerForce Elite - back cover for mobile phone
Back cover for mobile phone
Material
Polycarbonate
Silver
Apple iPhone X
Material
Polycarbonate
Silver
Carrying Case
Protective cover
Recommended Use
For mobile phone
Protection
UV-proof, scratch-resistant, drop-proof
Cover Type
Back cover
Apple iPhone X
Type: Case
Brand: Belkin
Price Range Ex VAT: 0 - 50
