The durable SheerForce Elite protective case is easy to grip and improves drop performance. Constructed of a UV-resistant material, your case maintains its clarity, even when exposed to the sun.
Strength and resilience
The polycarbonate construction combines aspects of plastic and rubber to provide strength and shock-absorption simultaneously. -
Improved drop performance
Engineered to successfully disperse impacts throughout the case and preserve the phone within. A unique molecular structure provides improved drop performance. -
Scratch-resistant case
Add a protective layer to defend against keys, debris and other items that can cause cosmetic damage to your iPhone. -
Everything counts
Even the edges of the case have been thoughtfully designed to prevent damage to your screen. A slightly raised edge provides a space between your screen and the surface when laying the phone screen down. -
Ready for anything
These cases withstand drops and abrasive components, ensuring advanced protection for your iPhone. They maintain their clarity and custom fit when exposed to extreme temperatures, high humidity, UV rays, solvents and heavy use over the lifetime of your phone. -
All access
Access points have been designed around ports and speakers, allowing full access to your phone's features. Buttons maintain "push+click" tactility while safely covered. Adjust volume, plug in headphones, connect charging cables and dock your iPhone X without removing the case.
- Belkin SheerForce Elite - back cover for mobile phone
- Product Type
- Back cover for mobile phone
- Material
- Polycarbonate
- Space grey
- Material
- Polycarbonate
- Space grey
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Protection
- UV-proof, scratch-resistant, drop-proof
- Cover Type
- Back cover
