Secure KVM Cable Kit is the easiest and neatest way to connect all your computers and servers to your KVM switches, providing image clarity for high-resolution applications. These cable kits offer high-performance, high-quality, and reliability. The Secure KVM Cable Kit features nickel-plated connectors with a gray jacket.
- Belkin Secure KVM Cable Kit - video / USB / audio cable - 3 m
- Video / USB / audio cable
- Length
- 3 m
- Connectors
- 4 pin USB Type B - male , 12+5 pin analogue DVI - male , Mini-phone stereo 3.5 mm - male
- Connectors (Second End)
- 4 pin USB Type A - male , 15 pin HD D-Sub (HD-15) - male , Mini-phone stereo 3.5 mm - male
- Designed For
- OmniView Secure 2-Port DVI-I KVM Switch w/Audio, 2-Port DVI-I KVM Switch w/Audio Plus, 4-Port DVI-I Dual-Head KVM Switch w/Audio, 4-Port DVI-I KVM Switch w/Audio Plus
- Length
- 3 m
- Connectors
- Designed For
- Belkin OmniView Secure 2-Port DVI-I KVM Switch w/Audio, 2-Port DVI-I KVM Switch w/Audio Plus, 4-Port DVI-I Dual-Head KVM Switch w/Audio, 4-Port DVI-I KVM Switch w/Audio Plus
