Your basket is empty
Belkin Secure Audio Switch
Quicklinx: BB4MWS00 Mfr#: F1DN104A
The Secure Audio and Microphone Switch can be used to reduce security risks caused by the vulnerabilities of analog signals in a digital environment by reducing the number of exposed microphones that can be exploited by malicious software attacks; reducing security risks caused by user errors when multiple headsets/microphones are preset; eliminating the microphone-switching function from the KVM to isolate it from the USB and PS2 signals; incorporating an external microphone mute button to shut off the microphone when the Switch is not in use or while handling calls where the microphone is not required; preventing the system's mute switch from being manipulated by software or driver with a hardware mute switch.
Belkin Secure Audio and Microphone Switch - audio switch - 4 ports - B2B
Audio switch - 4 ports
Subtype
Audio
Ports
4 x audio
AC 120/230 V
27.69 cm x 8.64 cm x 3.3 cm
0.75 kg
Manufacturer Selling Program
Belkin B2B
3 years warranty
Enclosure Type
Desktop
Subtype
Audio
Ports
4 x audio
Status Indicators
Port status
4 x audio output mini-jack , 4 x microphone input mini-jack , 1 x microphone input mini-jack , 1 x audio output mini-jack
External power adapter
AC 120/230 V
Belkin B2B
27.69 cm
8.64 cm
3.3 cm
0.75 kg
Limited warranty - 3 years
0 - 80% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
