Belkin Screen Protector for iPad Mini 3 - Transparent overlay
Quicklinx: B9Z9WS00 Mfr#: F7N276bt2
TrueClear Advanced Screen Protector for iPad mini 3 is the best screen protector available, engineered for strength and clarity and tested to meet optometric standards. The result is a crystal clear screen protector that keeps your screen safe from damage while still giving you an incredible screen experience.
Patented TrueClear technology allows light to pass through the screen protectors precisely and evenly, giving you a level of sharpness and vibrancy higher than even the leading competitor's high-definition products.
The screen protectors are tested for optical precision and clarity using the same methods optometrists use for eyeglasses. These tests, combined with third-party data, position TrueClear iPad screen protectors as the market leaders in clarity - the clearest screen protection.
  • Transparent iPad mini 3 screen protector
  • Pixel for pixel, clearest protection available
  • Market leader in clarity
    The screen protectors are tested for optical precision and clarity using the same methods optometrists use for eyeglasses. These tests, combined with third-party data, position TrueClear iPad screen protectors as the market leaders in clarity - the clearest screen protection you can buy.
  • Fast, easy application
    Applying your iPad mini 3 screen protector is fast and easy. Start by cleaning your screen with the included cleaning wipe and dust removal film, then peel the overlay from its backing and place it onto your screen. Finish by using the included smoothing card to push away creases and bubbles.
Belkin TrueClear - screen protector for tablet
Screen protector
Intended For
Tablet
Protection
Scratch-resistant
Package Content
2 screen protectors, smoothing card, cleaning wipe, dust removal sticker
Transparent
Screen protector
Intended For
Tablet
Protection
Scratch-resistant
Package Content
Transparent
Tru Clear technology
Lifetime
