Belkin Screen Protector for iPad Air 2 - Transparent overlay
Quicklinx: B9Z8WS00 Mfr#: F7N262bt2
Device Type: iPad Air 2
18 in stock
£11.85 ex VAT
£14.22 inc VAT
TrueClear Advanced screen protector for iPad Air 2 is the best screen protector available, engineered for strength and clarity and tested to meet optometric standards. The result is a crystal clear screen protector that keeps your screen safe from damage while still giving you an incredible screen experience.
Patented TrueClear technology allows light to pass through the screen protectors precisely and evenly, giving you a level of sharpness and vibrancy higher than even the leading competitor's high-definition products.
The screen protectors are tested for optical precision and clarity using the same methods optometrists use for eyeglasses. These tests, combined with third-party data, position TrueClear iPad Air 2 screen protectors as the market leaders in clarity - the clearest screen protection you can buy.
  • Transparent iPad Air 2 screen protector
  • Pixel for pixel, clearest protection available
  • Market leader in clarity
  • Fast, easy application
    Applying your iPad Air 2 screen protector is fast and easy. Start by cleaning your screen with the included cleaning wipe and dust removal film, then peel the overlay from its backing and place it onto your screen. Finish by using the included smoothing card to push away creases and bubbles.
Belkin TrueClear - screen protector for tablet
Screen protector
Intended For
Tablet
Protection
Scratch-resistant
Package Content
2 screen protectors, smoothing card, cleaning wipe, dust removal sticker
Transparent
Apple iPad Air 2
Screen protector
Intended For
Tablet
Protection
Scratch-resistant
Package Content
Transparent
Tru Clear technology
Lifetime
Apple iPad Air 2
Belkin Screen Protector for iPad Air 2 - Transparent overlay Bundle deal on Belkin Screen Protector for iPad Air 2 - Transparent overlay
£111.02
Brand: Belkin
Price Range Ex VAT: 0 - 50
