Resist fingerprints and other smudges on your screen with an protector that prevents the build-up of dirt from daily use. Avoid damage without affecting your touchscreen's functionality. Strong yet thin and lightweight, the protector provides excellent protection that will help keep your device looking like new.
Shield against smudges
Resist fingerprints and other smudges on your screen with an protector that prevents the build-up of dirt from daily use. -
Defend your device
Avoid damage without affecting your touchscreen's functionality. Strong yet thin and lightweight, the protector provides excellent protection that will help keep your device looking like new. -
TrueClear
See your screen, not the protector. TrueClear technology ensures optimal screen visibility. -
Fast install
Applying the protector is fast and easy. Simply clean your iPad Air screen with the included cleaning wipe, peel the protector from its backing and place it onto your screen. Then use the included smoothing card to push away creases and bubbles.
- Belkin TrueClear Anti-Smudge Screen Protector - screen protector for tablet
- Product Type
- Screen protector
- Intended For
- Tablet
- Protection
- Scratch-resistant
- Package Content
- Cleaning cloth, screen protector, smoothing card
- Limited lifetime warranty
- Product Type
- Screen protector
- Intended For
- Tablet
- Protection
- Scratch-resistant
- Package Content
- Anti-fingerprint, Tru Clear technology
- Lifetime
