Belkin Rugged Protective Sleeve Case for MS Surface 12" - Black
Quicklinx: BB6PWS00 Mfr#: F7P354btC00
The ultra-light and protective Type N Go Sleeve is the ideal accessory for your Microsoft Surface. Specifically designed for lap use, it's perfect for typing on uneven areas. Enough room to carry both your keyboard and tablet, it's also slim enough to easily stash in a backpack or handbag.
Using a tablet without a flat surface can often be challenging or just plain uncomfortable. That's why the Type N Go sleeve has ergonomically molded contours. This unique wave-like design props up and secures your device even on subways and bumpy car rides letting you type or watch online content in comfort.
Now it's easy to take your Surface Pro and keyboard all in one slim and convenient case.
  • A perfect surface
  • Ideal for lap use
  • Fits with & without keyboard
  • Stylus storage
    Keep your stylus safe and easily accessible with a convenient storage loop.
  • Protect & go
    Stylish and durable, the zip-up sleeve provides just the right fit for preventing damage to your Microsoft Surface Pro. A soft inner lining also protects the screen and back from scratches while you're on the go.
  • Easy access
    Simply zip up the sleeve to keep your Microsoft Surface Pro 3 safe and secure when you're on the go. When you need your tablet, it's quick and easy to zip open and grab.
Belkin Type N Go - protective sleeve for tablet
Protective sleeve for tablet
Screen Size Compatibility
12"
Material
Neoprene
Blacktop
Material
Neoprene
Blacktop
Carrying Case
Protective sleeve
Recommended Use
For tablet
12"
Protection
Scratch-resistant
Additional Compartments
Stylus
Stylus holder, soft inner lining, molded
